Author Topic: Rear ABS sensor - re-setting onboard cpu  (Read 1006 times)
Offline NickyJ
« on: 25 September 2006, 11:25 »
Hi all,
I have not been on the board for a while - I hope everyone is well.  :smiley:
I have just brought a replacement ABS sensor for my rear right wheel as the old one was giving a fault and shutting down the ABS and
I have a couple of questions:
1. Once fitted, do I need to reset the onboard cpu for the fault to be removed, or will it do it automatically once the new sensor is in place?
2. When I went to remove the wheel nut guards to get to the bolts on the alloys - i found they were tricky to get off, and I was starting to scratch the metal. What can I use to safely remove these?
3. I am thinking about buying a cable so I can jack my laptop in into the cars's cpu, as I have been using someone else's up untill now, and was wondering where I could download a copy of the fault diagnosis software?
Also, I have noticed that the driver side window sometimes does not want to open or close - it tends to fix itself after 20 mins or so once the engine has been running - any ideas?
Help much appreciated,
Nick  :smiley:
« Last Edit: 25 September 2006, 12:14 by NickyJ »
'98 R reg Mk 3 Golf GTi "Mystic Blue"
Offline adyh
Re: Rear ABS sensor - re-setting onboard cpu
« Reply #1 on: 25 September 2006, 13:43 »
1. It should reset after you have moved a couple of metres .
2. I use long nose pliers
3. Normally available at all good sources of dodgy software.
Offline daz123
« Reply #2 on: 10 October 2006, 20:16 »
i have ordered cable and software for laptop , will copy aslong as you cover post and cd
cheers daz
Offline NickyJ
« Reply #3 on: 11 October 2006, 09:42 »
Cheers guys,
Sorry for my delayed response, been away for a bit.
Have now got software and cables for VAG so will set to work at the weekend to get it all fixed.
Will let you know how it goes.
Nick
