Hi,
I have found some mk4 calipers for £129 for the pair and wonder if it would be better, and worth upgrading my seized mk2 rears with these.
I understand that the fitting for the calipers, ie. the two bolt holes either side are standard on all golf models, however the mechanism itself is different, with different hose connections.
Would they bolt straight on to my existing 239mm (i think) disks?..... and would all I need is different hose connectors, if so, where would I be able to get the adapter pipes?
thanks
