Author Topic: Golf GTI 8v - Stalling Problem  (Read 1866 times)
Offline davel
« on: 20 September 2006, 17:33 »
Hi,
I am looking for a little help with my Mk 3 Golf GTI (8v and about 85K on the clock). The car is a good runner except for its frustrating habit of regularly stalling at lights, in traffic etc. From time to time when you dip the clutch as the car comes to a halt the engine revs will drop away to nothing and the engine will either stumble and recover or stall.
The problem occurs pretty regularly, often at least once on a quick trip of a couple of miles and sometimes upwards of half a dozen times on a cross country jaunt. The weather seems to make no odds and it will be just as happy to do it at the end of my road or a couple of hundred miles into a journey.
The car is regularly serviced, only does about 6K miles a year and just passed an MOT with no problems. Since I have owned the car it has had most of the ignition system replaced (plugs, HT leads, dist cap, coil), new exhaust (from behind the cat), new battery and that is about it. None of these have resolved the issue (not that I expected them to).
I have had it looked at twice. First mechanic said the lambda sensor was shot, although no fault codes were logged with the engine management system. Second time was during my last MOT where they said it was fine. Could this be the culprit? If so it looks pretty easy to swap out myself.
Any ideas gratefully received. Doesn't really bother me that much, but my girlfriend isnÂ’t too keen on driving it when it randomly stalls all over the place!
Thanks
Dave
Offline AudiA8Quattro
Re: Golf GTI 8v - Stalling Problem
« Reply #1 on: 20 September 2006, 17:52 »
Replace the ECU(no.167) and Fuel Pump(no.30) relays.
They look like this.
Offline davel
« Reply #2 on: 20 September 2006, 18:20 »
Thanks, will give it a try tomorrow.
After a bit of digging through past threads it also looks like giving the throttle body a good clean wouldn't hurt either.
For what it's worth this only happens when slowing to a stop and dipping the clutch, not when I am just driving along, and the car always restarts first time. Makes it a little easier to live with I guess.
Offline monkeyalan
« Reply #3 on: 20 September 2006, 18:53 »
yup, do the throttle body too.  :wink:
Offline gronows gti
« Reply #4 on: 20 September 2006, 22:13 »
i had stalling with my 1995 8v then it got to stage where it wouldnt start i took it to vw specialists nothing came up on fault finder so i got impluse sensor changed and its been brillant for months since then.all in it cost 173quid to be changed thatwas the impluse sensor,diagnostic and hour labour so not bad.my mate had same problem with his 2weeks after me and he had his done in same place and his aint had problem since either.
Offline davel
« Reply #5 on: 22 September 2006, 08:50 »
Thanks everyone, cleaned about a gallon of gunk out of the throttle body last night and running like a dream now.
Appreciate the help.
Offline monkeyalan
« Reply #6 on: 22 September 2006, 11:44 »
good init  :grin: free performance!  :cool:
