Author Topic: 3DR GOLF - Drivers Side Door Sensor / Courtesy Light  (Read 6281 times)
Offline s4k1b
« on: 10 September 2006, 22:09 »
When i open my drivers door.... the little red light on the doorcard doesnt come on... neither does the interior courtesy light....
Im thinking theres something wrong with the door sensor.... but where is this ??  On msot cars its usually a little switch that is pressed in when the door is shut... but i cant find it!!!
Any ideas ?
« Last Edit: 10 September 2006, 22:12 by s4k1b »
Offline Rhyso
Re: 3DR GOLF - Drivers Side Door Sensor / Courtesy Light
« Reply #1 on: 11 September 2006, 08:27 »
sounds like you've blown a fuse.  Do you have central locking / leccy windows? if they have stopped working its definiately a fuse.
edit - thinking about it it could also be a faulty lock module; does your light come on when you open the other door? if that's the case then you need a new lock module  :sad:
« Last Edit: 11 September 2006, 09:24 by Rhyso »
Offline s4k1b
« Reply #2 on: 11 September 2006, 11:36 »
The light comes on when i open the other door yes.  Lectric windows central locking all work fine.   I thought the switch would be built into the lock.... but i turnd the lock on the passengers side with a screwdriver so that the car thinks the door is shut.... the light was still on ?
isnt there a switch elsewhere or is it just in the lock itself?
Offline Rhyso
« Reply #3 on: 11 September 2006, 12:03 »
the switch is built into the door lock module I'm afraid mate.
Not sure of cost but i think the module is around £100 alone  :sad:
do you have problems locking the door? i.e does the door pin pop back up?
Offline s4k1b
« Reply #4 on: 11 September 2006, 12:11 »
Everything works fine ! Just ....
1. the courtesy lights inside the car dont come on when door is opened
2. the red/white safety light on the doorcard doesnt come on
3. the buzzer doesnt sound when i leave the lights on and open the door
Offline Rhyso
« Reply #5 on: 11 September 2006, 12:22 »
i'd say the module then mate.  what happens is that the solder within it breaks down and the connections are lost.
you can take it apart and re-solder them but I believe its a pig of a job.
Offline s4k1b
« Reply #6 on: 11 September 2006, 12:30 »
does that require taking the door card off etc?
hmm i might just leave it
Offline Rhyso
« Reply #7 on: 11 September 2006, 12:40 »
it does indeed  :sad:
door card is 3 phillip screws and 3 T20 torx bits and held in place by clips.  its not too difficult getting the card off you just got to make sure you don't pull too hard otherwise you'll all the wiring with it!
have a look at this guide
that tells you how to remove the dor card
this tells you how to remove the lock etc
http://forums.vwvortex.com/zerothread?id=1015107
and this one explains the problem in more detail
http://forums.vwvortex.com/zerothread?id=1542461
Happy reading lol
« Last Edit: 11 September 2006, 12:46 by Rhyso »
Offline s4k1b
« Reply #8 on: 11 September 2006, 13:11 »
cheers mate. your a star !  :cool:
Offline s4k1b
« Reply #9 on: 11 September 2006, 13:26 »
looks like more hassle than its worth... dont want to end up buggering the central locking n door electrics too... i think i'll leave it...
unless u kno wher the fuse is for this particular mechanism ? lol it might b the fuse
