Author Topic: Rear Heated Screen not working  (Read 1948 times)
Offline JMallows
« on: 02 September 2006, 23:05 »
The heated screen in the MK4 isnt working anymore. I have the checked the fuse, which is fine, and am now not too sure where to look. I tried to get the switch out, but only managed to get a cover off, which doesnt help! :)
Any ideas where to look next? :)
Thanks
A clever person solves a problem. A wise person avoids it.
Offline Mantamad
Re: Rear Heated Screen not working
« Reply #1 on: 03 September 2006, 23:49 »
Have you checked thats its working with the engine running? many cars prevent the rear screen from working while the engine is off to save on battery drain.
I would start by checking the connections at the window itself,  switch on and put a test meter across the terminals to see that you are getting 12v to the window, if you are then the element has a break in it (conductive paint can repair this) if no power showing then check the negative (earth) connection from the screen first, then trace your way back including the switch and the relay. If these check out OK, it might be a break in the wiring, the most likely place being where the wires pass from the car body into the back hatch.
Good luck!
Black 2002 GT TDi 130
Offline JMallows
« Reply #2 on: 04 September 2006, 20:52 »
thanks for this, will try this all,had assumed that it may well have been the switch,which seems to be more complex than a simple mechanical switch....they are getting more complicated ....ta for help....
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #3 on: 05 September 2006, 20:52 »
Have you actually switched it on :grin: :grin: :grin: :grin:
Offline JMallows
« Reply #4 on: 06 September 2006, 22:21 »
 :rolleyes:  The Switch depresses, and clicks down in place, and comes back up again when pressed again, but the light in the switch doesnt come on, and the screen doesnt de-mist :) This is why i assumed it to be the switch! Dont know how to get it out though?
Offline GazB
« Reply #5 on: 07 September 2006, 16:20 »
it just pops out mate, wedge a small screwdriver down the one side and you should be in business
Offline JMallows
« Reply #6 on: 07 September 2006, 22:33 »
I did that, and couldnt get the actual switch out, only the cover thingy? I could see the workings of the switch, looks overly complicated  :rolleyes: but couldnt get to any connectors! I shall take a picture of thats any help?!
