Author Topic: VDO Gauges - Clarification of Wiring & Senders  (Read 19086 times)
Re: VDO Gauges - Clarification of Wiring & Senders
« Reply #10 on: 31 August 2006, 17:38 »
I would use the T piece for the old MFA temp sensor & the new temp gauge sensor rather than to fit a temp & oil pressure switch, you want the pressure switch to have good contact with the oil flow :)
AFAIK, G is for the gauge, and WK is for the wire from the old pressure switch. It may be the other way round but I'm pretty sure its that way!
Offline pegasus
« Reply #11 on: 31 August 2006, 17:44 »
So, where is the oil temp sender on my 16v engine and what is the part number of the audi item I require...
Cheers for the help jonny btw, I knew you'd be the man with the answers...
1.8 20VT GTI
« Reply #12 on: 31 August 2006, 18:00 »
on your 16v its on the back of the head, with a green/black wire.
049 919 563 A - Audi 180 degree sender - £12.19
Offline pegasus
« Reply #13 on: 31 August 2006, 18:04 »
thought it was, best check though ay...
So, Im now reckonin I need 2 of these T piece things... one for the oil pressure (VDO sender & original sender for warning buzzer thing which is on oil filter housing) and one for the temp senders (original one for MFA & 180 deg Audi jobby)
What do u reckon?
1.8 20VT GTI
Offline pegasus
« Reply #14 on: 31 August 2006, 18:12 »
I have a sender here that I pulled off the audi engine I took the gauges from, its part number is 027 919 501 and says 12v 120 deg with VDO Germany also stamped into it...
cant I use this?
1.8 20VT GTI
« Reply #15 on: 31 August 2006, 20:52 »
nooooo  :grin:
You need 1 t piece for the temp senders.  The 2 pole audi sensor REPLACES theold high pressure sensor, one connection on the sensor goes to the gauge, the other goes to the wire from the old pressure switch you've removed.
Offline pegasus
« Reply #16 on: 31 August 2006, 20:55 »
ok right
so the warning buzzer for high/low oil pressure will still work if I replace the original sender on the oil filter housing for the twin pole audi one yeah?
and, can I use the sender I have mentioned above for the temp or do I need the 180 deg jobby?
cheers
Paul.
« Last Edit: 31 August 2006, 21:02 by pegasus »
1.8 20VT GTI
« Reply #17 on: 01 September 2006, 08:28 »
Yeah you have the 1.8 bar twin pole sender, so it replaces the old white 1.8bar sender with a yellow wire.  The yellow wire is then connected to the twin pole sender, to pin WK.
I don't think that sender is the right one for the gauge, buy you can always try it!  You can compare the MFA reading to the gauge reading, if they're very different you got the wrong temp sender off the audi.
Judderi
« Reply #18 on: 01 September 2006, 08:48 »
Im still confused. Think ill just stop reading.
Offline pegasus
« Reply #19 on: 01 September 2006, 12:56 »
wicked, iv got the jist of things now  :cool:
job for tonight me thinks, the gauges are already in with 2 wires run through into the bonnet for the temp and pressure so all i have to do is replace the sender on the oil filter housing with the VDO twin pole jobby, plug new wire to 'G' and old wire to 'WK'. Then remove the temp sender from back of cylinder head, screw T piece in to head, then replace the original temp sender into T piece along with the audi one, plug new wire to audi temp sender and original to original... job done  :laugh:
1.8 20VT GTI
