Author Topic: sub amp combo  (Read 4771 times)
Offline mase
  • mk3 madness!!!
Re: sub amp combo
« Reply #10 on: 30 August 2006, 12:49 »
personally i still rave about the JL stuff..... their subs in particular, i had a sony 1200w sub hooked upto a kenwood 400watt amp for a while and it sounded ok, changed the sub for a JL w0 which is rated at 125w and it blew the sony away, the sound quality of them is, IMO, immense.
granted they have gotten a bit too comercial these days, but the subs still rock!!!
Quote from: Slick#13
I still see there is a distinct lack of b!tch tit getting outage.
...word
Offline Len
Re: sub amp combo
« Reply #11 on: 30 August 2006, 13:04 »
I wish manufacturers would only use the RMS wattage figures and not quote some stupid peak at 2 ohms totally unrealistic figures!
If you compare the RMS figures you will get true comparisons between components.
nearly used a JL sub in my new box, but it was too big out back!!!! :laugh:
www.sas.org.uk
www.the-ace.org.uk
Offline mase
  • mk3 madness!!!
Re: sub amp combo
« Reply #12 on: 30 August 2006, 13:45 »
but then our mate barryboy couldnt possible spend £23 down the car boot sale and come home with a 2000watt bumping sound system innit bruv  :laugh:
and yes, the JL are a lot more j-lo then kylie.... but when has that ever been a bad thing?  :wink:
...word
Offline Len
Re: sub amp combo
« Reply #13 on: 30 August 2006, 15:30 »
^^^^ Very true mate very true! :laugh:
Because of the size of the box I made (to fit behind the wheelwell of a Mk 3 boot)
it wasnt deep enough to fit a real huge magnet job sub! :sad:
But hey the sound is good enough for me and I accepted that it would be a compromise between size and space and remaining boot space when I embarked on that little project!
www.sas.org.uk
www.the-ace.org.uk
Offline mase
  • mk3 madness!!!
Re: sub amp combo
« Reply #14 on: 30 August 2006, 15:56 »
thats the only down side from making a custom space saving install, u cant usually get the dimensions right to get the most out of the sub.... but as long as it makes the hair on the back of your neck stand up all is good.
to wrap my opinion up....
JL sub + 6" component speakers, mated with kenwood headunit (find them very easy to use / tune) and amp  :cool:
...word
Judderi
Re: sub amp combo
« Reply #15 on: 31 August 2006, 13:13 »
It just so happens i have most of that for sale!
Offline Len
Re: sub amp combo
« Reply #16 on: 31 August 2006, 13:23 »
Well there are always compromises to make in life and that was one I decided to make!
Wanted a sub but wanted to keep as much boot space as possible.
And yes I'm more than happy with it! Not only the hairs on neck, I can feel the bass notes in my back! :grin:
I use the start of the Chicane CD to check subs! About 35 seconds in a long deep bass note starts and goes on at varying levels for a bout a minute. If a system at high volume produces that well then I class it as good.
www.sas.org.uk
www.the-ace.org.uk
Offline Uruk Hai
Re: sub amp combo
« Reply #17 on: 31 August 2006, 17:40 »
If you want a track to test out your gear listen to Afrika shox by Leftfield
Gti_gras
Re: sub amp combo
« Reply #18 on: 13 September 2006, 07:40 »
I am porting my system over from my vectra i have an american 1200w (550 rms) amp with a fan in it 2 jbl 6 X 9's 2 pioneer 12" subs in a 2.5 cl box with twin ports and a sony head unit, thing is i cant decide if i should keep the standard head unit and try to get a converter to convert my speaker output to rca output so i can keep use of the 6 cd shuttle or is it possible to get an adapter to get the 6 cd shuttle to work with another head unit.............
Gti_gras
Re: sub amp combo
« Reply #19 on: 13 September 2006, 07:44 »
Forgot to say i have a mk4 gti turbo with the gamma tape deck and 6cd shuttle in the boot.
