Author Topic: 16V running lumpy, a few questions..  (Read 1292 times)
Offline Xiotis
« on: 17 August 2006, 11:22 »
Hi all,
my newly aquired 16V GTI, is running lumpy  :sad:. Be it cold or hot.
I am thinking that one possibly culprit could be a vacuum leak and the rubber pipe directly above the AFM has some duct tape around it, I haven't removed the tape yet to investigate but I am thinking that this could be a source of my leak.
What is the best way to check for leaks? I have heard one method is to spray easy start around the vacuum pipes, is this a safe way to do it?
Also, where can i get a new pipe to replace my duct taped one? I tried the GSF web site but couldn't seem to find the part, anyone know what is the official name for it? Is it intake elbow boot?
Anywhere else I can try to purchase it? Is VAG worth a go?
Thanks!
Mk2 Golf GTI 16V
Offline Brads MK2 GTI
Re: 16V running lumpy, a few questions..
« Reply #1 on: 17 August 2006, 11:25 »
Not sure about easy start, but WD40 will ddo. Just get the engine running and spray away, if you hear a change to the engine note, you've got a leak. Just try VAG, not sure if they still carry them, or try a scrappy.
Judderi
« Reply #2 on: 17 August 2006, 12:04 »
If your intake hose has a split in it then it will deffo run lumpy and very badly. The whole intake system must be sealed in order for the k-jet mechanical injection system to function. Get yourself a new hose/boot!
Is it the bit that connects to the airbox you need?
Offline Gambit
« Reply #3 on: 17 August 2006, 12:46 »
scrapyards or there is plenty of people breaking golfs across the country!
VAG will prob charge you an arm & a leg
Judderi
« Reply #4 on: 17 August 2006, 13:30 »
ebay
Offline Xiotis
« Reply #5 on: 17 August 2006, 13:43 »
Thanks for the replys.
The part that I probably need is the boot that goes directly on the Air Flow Meter- that's the one which has got frayed Duct Tape on it!
Last week my MOT Centre adjusted the Co level to the correct level as she was running lean, if i find the leak will I need to get her readjusted?
Mk2 Golf GTI 16V
Offline Gambit
« Reply #6 on: 17 August 2006, 15:11 »
yep
Offline Xiotis
« Reply #7 on: 18 August 2006, 11:23 »
Well I checked the intake elbow boot and even though it had duct tape on it it looked pretty secure.
I sprayed WD40 around it and around a few of the pipes but there was no change at all in the engine idle. I didnt wait till the engine was warm though, would that make a difference?
I am thinking next to remove the ISV and clean it with carb cleaner and put some injector cleaner in the tank. Thoughts please.
Cheers guys.
« Last Edit: 18 August 2006, 11:26 by Xiotis »
Mk2 Golf GTI 16V
