Author Topic: Lowering springs  (Read 950 times)
Offline owls88
Lowering springs
« on: 14 August 2006, 19:40 »
i've seen sum jamex springs and i want to lower my 1.3   60mm, but it says i need shortened dampers ? is this true or can i just buy the springs and have them fitted without altering anything else?
Offline Agreeable Slick
  • Unit
Re: Lowering springs
« Reply #1 on: 14 August 2006, 19:51 »
you will need to uprate your dampers. Otherwise the standard ones will fatigue quickly and begin to leak.
Offline Dub-77
  • Dub again MK1 Golf Project
« Reply #2 on: 14 August 2006, 19:52 »
40mm is ok on std shox but you will find on a 60mm drop your shox will bottom out i think.
Show me a man with a tattoo and i'll show you a man with an interesting past :wink:
Offline owls88
« Reply #3 on: 14 August 2006, 19:54 »
so if i bought sum 40mm spring i woludnt need to update the damper and could keep them the same , there in mint condition because the cars been garaged for 16 years and has done only 39 000 miles
Offline Dub-77
« Reply #4 on: 14 August 2006, 19:56 »
Yeah I reckon you will be ok on a 40mm drop with std shox :wink:
Offline Organisys
  • Old and Slow...
« Reply #5 on: 14 August 2006, 20:44 »
Get yourself some Eibach springs, they are designed to work with OEM dampers.
Offline AudiA8Quattro
« Reply #6 on: 14 August 2006, 21:05 »
In my opinion it is pointless to change the springs without changing the dampers and top mounts.
May as well do the lot while its apart, its not that expensive.
