Author Topic: Indicators  (Read 2037 times)
Offline 152GTI
Indicators
« on: 14 August 2006, 15:35 »
Recently I had a standard VW head unit and 6 disc boot changer fitted to my Golf, however since it was fitted my indicators don't work! The fuses have been checked and are fine and the hazards work fine to.
Any idea why this has happened?
Offline Rhyso
Re: Indicators
« Reply #1 on: 14 August 2006, 15:57 »
is it both front and rear indicators?? just one side??
Offline 152GTI
Re: Indicators
« Reply #2 on: 14 August 2006, 16:08 »
Both front and rear, left & right.
Offline Rhyso
Re: Indicators
« Reply #3 on: 14 August 2006, 16:25 »
have you tried removing the stereo to see if they start working again?
it could be your flasher module which i believe is part of your hazard light switch; though from what I've read normally the hazards dont' work either  :undecided:
that tis a strange problem you've got  :sad:
Offline ub7rm
Re: Indicators
« Reply #4 on: 18 August 2006, 12:57 »
Perhaps you have accidentally dislodged the cable from the indicator stalk to the flasher module?? Given that the hazards work but not when you flick the stalk this seems a possibility.
2020 BMW 128ti
2017 Golf GTD Estate
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: Indicators
« Reply #5 on: 19 August 2006, 06:05 »
Do the rest of the functions on the stalk work correctly?
Offline 152GTI
Re: Indicators
« Reply #6 on: 25 August 2006, 22:24 »
Ive finally had the problem fixed with my indicators, all I had done was knocked a lead linked to the indicator but a friend checked it out and just put it back in it's place and so far it's all been good!!!
 :smiley:
