Author Topic: 4wd drive but what engine?  (Read 1626 times)
Offline ova
« on: 08 August 2006, 17:58 »
ok, so ive got the 4wd drive subframes with driveshafts and a motor etc coming but......
(allthough i need the sheel at moment!) .. i dont have a clue what engine to run?
can i run the vry motor on this subframe? is the vr6 gear box different to the gti????
or do i run a 2.0 and do the head etc....
heeeeeeelp!
also if anyone around oxford has a half decent mk2 lieing about... could the holla
cheers
Offline monzablue16v
Re: 4wd drive but what engine?
« Reply #1 on: 08 August 2006, 18:57 »
I don't think the syncro 4wd system will take a lot of power through it as I had a similar idea for a project.
Offline ova
« Reply #2 on: 08 August 2006, 19:02 »
this is true, but if it does fail then ill just have to make some stronger parts... and at the end of the day i can allways revert to the standard front wheel drive,
but what engine!
« Reply #3 on: 08 August 2006, 19:14 »
Fair enough! Personally I'd go for a 1.8T or VR6, can't help much on the helpful what fits bit but this page should come in useful :)
http://www.golfgtiforum.co.uk/index.php?board=40.0
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 08 August 2006, 19:21 »
sounds like a bit of a monster project if you're starting from scratch with a few 4wd bits.. i assume you know its not a straight forward bolt-on job to a normal mk2 shell ?
Offline ova
« Reply #5 on: 08 August 2006, 20:05 »
yeah, theres a spot of cutting and shutting... is it to get the rear diff in or for the prop shaft? got the welder and the grinfer reasy!  :nerd:
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 08 August 2006, 20:09 »
both :grin:
get yourself to a show and have a nosey underneath a synchro or a rallye to see how it all goes in.
as for the engine.. G60.. 1.8T .. 16vT .. VR6T .. all depends how mad you want to go.
Offline ova
« Reply #7 on: 08 August 2006, 21:36 »
ill try and do that... any near oxford???
I started off in the jap scene and i no there just reverting to naturaly aspirate motors again so i think i might stay non turbo.... but still try and get around 200 horsies!
what u think to a 2ltr golf 16v,,,, get cams, port and polish, bigger inlet, and then a nice liel 4 into 1???? maybe then lughten the fly wheel etc...
Judderi
« Reply #8 on: 09 August 2006, 13:15 »
Your idea for a 2.0 16v will get you in the region of 200bhp take a little. You might benefit from Throttle Bodies better than the k-jet setup which kinda tops out at 200bhp. Along with this you will need a suitable 4wd gearbox as a normal 2 wheel drive one wont mate up to your 4wd setup.
Offline Organisys
  • Old and Slow...
« Reply #9 on: 09 August 2006, 13:29 »
Why not just buy a G60 Syncro?
well, or find one as a donor. 200bhp from a G60 is reasonably easy.
