Author Topic: mfa not working  (Read 1085 times)
Offline dodgyracer
mfa not working
« on: 07 August 2006, 01:24 »
Hiya guys, i'm having trouble getting my mfa working, when i press the button nothing moves, it doesn't even go through the menu's any ideas??
Offline ChrisO GolfO
  • See thru it
Re: mfa not working
« Reply #1 on: 07 August 2006, 12:20 »
The Contacts on the Switch on the Stalk could do with a clean or take them apart and replace them...
Who wanna get halfed up by a half wit
Who got a gang a problems
And dont give a half sh!t b!tch
Offline dodgyracer
Re: mfa not working
« Reply #2 on: 07 August 2006, 13:39 »
i'ts a brand new stalk though
Offline Gambit
Re: mfa not working
« Reply #3 on: 07 August 2006, 13:42 »
contacts has nothing to do with the MFA. there is a electrical plug/connector that comes off the MFA stalk. i assume you have connected it?
if not then take off the bottom of the steering column housing - 2 screws - and check its conntected correctly
if you connect it back to front then the slider switch on the stalk will move the MFA modes rather than the button!!
Offline kappatango
  • From Rice to V-DUB : No Going Back
Re: mfa not working
« Reply #4 on: 08 August 2006, 17:54 »
try pulling fuse 3 (on an 8v) for about 5 secs......need to take it right out.  I did it on my completely fooked MFA and now all working great.
Its not about how fast you drive - Its how you drive fast.......
Offline frog
Re: mfa not working
« Reply #5 on: 08 August 2006, 21:05 »
Fuse 21 on 16v
Re: mfa not working
« Reply #6 on: 10 August 2006, 09:45 »
fuse 21 on a late spec MK2, fuse 3 on an early one ;)
Hazard switch on dash = early, hazard on column = late.
