Author Topic: Rim & tyre sizes  (Read 3155 times)
Offline BigDaveC
Rim & tyre sizes
« on: 20 July 2006, 18:38 »
If I were to change my 14" with 185/60 to 15" 185/55 would that be equal ??? surely not ?
Online jv
  • Administrator
Re: Rim & tyre sizes
« Reply #1 on: 20 July 2006, 18:48 »
185/55/15 would be cool or 195/50/15
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline BigDaveC
« Reply #2 on: 20 July 2006, 18:55 »
will those sizes lift the car off the floor a bit, but keep the wheel arch clearence the same ?
Online jv
  • Administrator
« Reply #3 on: 20 July 2006, 19:01 »
neither should make any difference as the whole point is that the overall size stays the same
Buy site stuff!
Offline BigDaveC
« Reply #4 on: 20 July 2006, 19:20 »
I've slight scrubbage on the drivers side when i go over speed bumps.
I wondererd weather i could lift the car a bit without changing the springs.
The camber also needs doing since the lowering. Does this affect aswell the height ?
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 20 July 2006, 19:22 »
if you're going 15's you have to run 195/45 rubber... on a 8 inch rim
Online jv
  • Administrator
« Reply #6 on: 20 July 2006, 19:25 »
So you currently have what, 6 by 14's and they are catching the arches? Something not quite right there
Buy site stuff!
Offline BigDaveC
« Reply #7 on: 20 July 2006, 19:36 »
no, something catching slightly underneath on the drivers side over speed humps. Arches are fine.
Will the camber adjustment sort that out.
Will bigger wheels sort it ?
Offline Dizzie
« Reply #8 on: 20 July 2006, 20:02 »
you should be able to see what's catching just by looking.
should always get the geometrey done when you've done anything to the suspension.
as long as the rolling diametre is the same having a different size wheels won't change anything really. may corner slightly different to the change in tyre wall.
Offline BigDaveC
« Reply #9 on: 20 July 2006, 20:10 »
It's a beam further back that the wishbone arm, just underneath the footwell bit.
I've just been outside and the drivers side is about 1cm or so lower than the passenger side.
I haven't had the alignment / camber done yet. Does this sound like the problem ? or are you able to untighten the top mount suspension bolt on the driverside???
« Last Edit: 20 July 2006, 20:15 by BigDaveC »
