Author Topic: Dont believe this.... please help!!  (Read 3986 times)
Offline gibson
« on: 19 July 2006, 12:49 »
ok so i was chuffed that i got meself a set of audi 18" alloys for the mk4. Just spent a fortune on a set of 4 tyres aswell and when ive went to fit them today they dont bloody fit!!!  :angry: :angry:
They go on ok but the holes for the bolts aint lining up. The golf ones are smaller than the holes on the audi wheels (if that makes sense).
Please can someone tell me if there is a way round this, hopefully an easy and cheap way lol. I was led to believe audi 5 studs fit straight onto vw 5 stud cars. Is there a spacer or adaptor of some sort i could use.
Thanks for any help
Offline gibson
« Last Edit: 19 July 2006, 13:49 by gibson »
Offline topher
  • Administrator
  • fully functioning
Re: Dont believe this.... please help!!
« Reply #2 on: 19 July 2006, 13:50 »
i dont see anything useful in that link mate.
mk4 golfs use a 5x100 pcd, similar chassis'd audis (not including S3 and TT) use 5x112 .. you can probably get an adaptor set but it might mess up the offset, and push the wheels too far out.
sensible choice would be to sell the wheels and get a correct set unfortunately :undecided:
Offline tobz.
« Reply #3 on: 19 July 2006, 13:53 »
D'oh toph beat me to it
Check out this link:
http://www.leightyres.co.uk/catalog/fitment.php
It lists the pcd of all different manufacturers.
The link you posted only had spacers, you need some proper pcd adaptors but at over 10mm thick they are gonna lower the offset and probably result in arch rubbing.
Fitting some sort of audi hubs/disks is probably the solution but probably more costly than some suitable rims  :angry:
You got any pics of your dad's split ?
Offline tobz.
« Reply #4 on: 19 July 2006, 13:56 »
The adaptors in the second link wont work either, porsche 911 are a 5x130mm stud pattern.
Offline Horney
« Reply #5 on: 19 July 2006, 14:00 »
But those wheels WILL fit Late Bay campers and vans and all T3 Wedge campers and vans so there is a big market for them if you need to sell them on.
Nick
Offline tobz.
« Reply #6 on: 19 July 2006, 14:02 »
If you really want to proceed with the audi rims these are what you need:
http://www.evolutionsports.com/productDetail.cfm?catID=114&ProductID=1644
though at 20mm thick I'm sure there would be further trouble ahead!
D@mn right Nick (although the centre bore needs enlarging a bit) hmmmm 18" audi rims for yer wedge anyone :)
Offline gibson
« Reply #7 on: 19 July 2006, 14:04 »
Thanks for the help you guys. Im totally gutted. Im gong to put them in the saes section (maybe ebay too). what do you think i should be asking for them.
Should of researched this more lol
Offline jude202
« Reply #8 on: 19 July 2006, 14:05 »
Spent two years in a VW & Audi dealers parts dept. Never encountered any adapter which would let you fit those wheels.
Try getting the manfacturer's code from the rim. Your dealer should have a book which will cross reference this code with a company.
You could sell your wheels. Contact the manufacturer and order a set of blank alloys in the same design which you can the holes bored in.
Probabley expensive though . . .
Offline gibson
« Reply #9 on: 19 July 2006, 14:17 »
im gonna cut my losses, sell them and get some others with the cash ;)
Thanks for the links and help. Anyone wanting some 18's get yourself in the for sale section...
