Author Topic: air con  (Read 1381 times)
Offline bonedriven89
air con
« on: 19 July 2006, 09:26 »
I'm looking to get a mk4 gti - could someone explain the difference between the standard air con and the climatronic. Is the climatronic a air con unit ?? was in a mates and he had the climatronic thing and it didn't seem to be that cold at all even on full blast ? Can anyone tell me whats the difference !
Offline topher
  • Administrator
  • fully functioning
Re: air con
« Reply #1 on: 19 July 2006, 10:02 »
climatronic wont blast ice cold air out unless you force it to (set it to LO , full fan speed and drivers face vents) .. it basically keeps a steady temperature in the car (that you set) without blowing your face off. you just set it and leave it.
manual aircon you have to keep fiddling with the dials to maintain a constant temperature.
Offline The Doc
  • E63s Estate - Vito Sport
Re: air con
« Reply #2 on: 19 July 2006, 22:18 »
Agreed - it trys to keep the temp that you have set!
Sugar79
Re: air con
« Reply #3 on: 20 July 2006, 18:12 »
i have the standard air con and i dont have to fiddle with it to keep it constant  :sad:
Offline gibson
Re: air con
« Reply #4 on: 21 July 2006, 13:41 »
who needs air con when you have electric windows and a motorway nearby  :grin: :grin:
put your foot down on that accelerater and the wind will sort you out.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: air con
« Reply #5 on: 22 July 2006, 00:39 »
I turned off the a/c & undid window on the motorway, the other day - It was like the warm waft of you air you get when you open the oven door!!! :grin:
Def could not live without a/c, now!!
Climatronic cars seem to have probs with the fans/switches, so I would recommend the manual a/c! :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
