Author Topic: Timing belt change...  (Read 8588 times)
Offline workhorse '90 8v
Re:Timing belt change...
« Reply #10 on: 18 December 2003, 14:26 »
Gambits method it is then!!!
Offline Gambit
« Reply #11 on: 18 December 2003, 14:27 »
make sure you get the belt from VAG
« Reply #12 on: 18 December 2003, 14:29 »
A belt is not a belt then?
Are there probs with non VAG belts?
Offline Gambit
« Reply #13 on: 18 December 2003, 14:36 »
you have a comeback if the belt snaps within its life expectancy
something u dont if you get the belt from elsewhere
« Reply #14 on: 18 December 2003, 14:37 »
Good point
Offline richandhazel
« Reply #15 on: 18 December 2003, 14:51 »
I like Gambits idea, however, could be tricky if you want to replace the tensioner too. I usually replace the tensioner every other cambelt change (80,000 miles)
« Reply #16 on: 18 December 2003, 14:56 »
are the tensioners prone to failure?
« Reply #17 on: 18 December 2003, 14:58 »
I've no history what so ever with my car, so i'm thinking i should replace the tensioner...
Offline Gambit
« Reply #18 on: 18 December 2003, 14:59 »
i'd get the tensioner replaced also then
« Reply #19 on: 18 December 2003, 15:03 »
Yep, they can fail. Usually the first sign that they are starting to fail is they start making a noise that can easily be mistaken for alternator bearing noise.........eventually they can sieze and break up.
Be aware though, overtightening the timing belt can cause the same noise..........
