Author Topic: Timing belt change...  (Read 8571 times)
golfvr6
Re:Timing belt change...
« Reply #20 on: 18 December 2003, 16:35 »
Always get a new belt and tensioner from VW. I strongly recommend doing the job by the book, bodging it can be costly in the long run. If you want a bodge job go to kwik fit!
Offline workhorse '90 8v
« Reply #22 on: 20 December 2003, 13:13 »
an easy bodge way of doing it is, cut the exisiting belt in half all the way round
pull that half off, slide the new belt on - then pull rest of the old belt off and slide the new belt over
Could a new belt be put on using this method, then the old tensioner removed and replaced?
Would save a load of hassle?
golfvr6
« Reply #23 on: 20 December 2003, 18:04 »
To be honest its not a lot of hassle to do the job properly. If you are not sure either get someone to help you who knows or just get someone else to do it.
« Reply #24 on: 22 December 2003, 11:45 »
Fair enough.
what sort of cost would we be lookin at with labour included?
golfvr6
« Reply #25 on: 22 December 2003, 13:09 »
Under 200 quid all in.
« Reply #26 on: 22 December 2003, 13:18 »
Will deffinately be doing the work myself then!!!!!!
Offline Davo13
« Reply #27 on: 22 December 2003, 21:27 »
I had my cambelt replaced a couple of months ago by a garage and it costs about 100 quid.
golfvr6
« Reply #28 on: 22 December 2003, 22:29 »
Was that with a new tensioner? make sure you get genuine belt and tensioner from vw.
