Author Topic: Clocks ..  (Read 4227 times)
Offline workhorse '90 8v
Clocks ..
« on: 16 December 2003, 19:11 »
Simple question -
i have a1990 8v with bust rev counter,
will pre 1990 clocks fit (same multi plug?)
or do i need 1990 onwards clocks? :)
Offline Rob
Re:Clocks ..
« Reply #1 on: 16 December 2003, 19:14 »
what you mean by bust rev counter?
have you tried the fuse trick
Re:Clocks ..
« Reply #2 on: 16 December 2003, 19:22 »
yes yes yes
comon problem - a small component in the instrument cluster blows,
leaving the rev counter and MFA not working
apparently it can be fixed for 140 quid !!
stuff that, get a second hand set of clocks for ?50 (hopefully less)
thanx for helping tho ;)
Offline Dizzie
  • Make friends with your fast
Re:Clocks ..
« Reply #3 on: 16 December 2003, 19:35 »
I got a set of '88 16v clocks for ?10 from the scrapper.
Re:Clocks ..
« Reply #4 on: 16 December 2003, 20:25 »
NIce !
i'm still wonderin if those 88 clocks are the same as in a 90 ?
Blue MK2
Re:Clocks ..
« Reply #5 on: 16 December 2003, 20:33 »
i think the 88 ones have 2 plugs and the 90 ones have a single plug.
have a go and see if it fits?
If not then switch the rev counter over from the spare unit
Re:Clocks ..
« Reply #6 on: 16 December 2003, 20:40 »
have you done this?
Blue MK2
Re:Clocks ..
« Reply #7 on: 16 December 2003, 22:04 »
i know someone that has swapped there rev counter over so their milage stays the same.
Offline Gambit
Re:Clocks ..
« Reply #8 on: 17 December 2003, 09:23 »
im not sure if you can put a motometer(twin plug) rev counter into a vdo(single plug) unit.
complete units are easily sourced for around ?50.
Offline reserves
Re:Clocks ..
« Reply #9 on: 17 December 2003, 16:41 »
All post 90 Golf's are 24 pin single plug units, pre 90 double plugs will not fit.
I have a spare single plug unit showing 91,000. Let me know if you want it.
Both VDO & Motometer make the single plug ones btw.
Simply(!) swaping the rev counter over will not fix the MFA issue, the whole instrument panel needs to be replaced.
Rich. shinecello@hotmail.com
« Last Edit: 17 December 2003, 16:44 by reserves »
