Author Topic: Pierburg Idle Speed Adjustment  (Read 3879 times)
Offline keithyboy
« on: 21 June 2006, 18:17 »
How do I do it? I can't see anything that looks vaguely like an idle adjustment screw.
Wrong wheels and mine's Calypso not snot but it's close enough
Offline takethefifth
Re: Pierburg Idle Speed Adjustment
« Reply #1 on: 21 June 2006, 18:52 »
Don't know anything about the pierburg but this might help...  http://www.golfgtiforum.co.uk/index.php?topic=33259.0
Worth a try anyway! Looks like an idle screw on there somewhere.
Offline keithyboy
« Reply #2 on: 21 June 2006, 21:35 »
Still not sure. HBOL suggests the you turn the idle control valve on the back of the 3/4 unit thing. Can anyone shed any light?
« Reply #3 on: 22 June 2006, 13:15 »
there is only a screw in the top which adjusts the CO, if the idle is out then its because something else is wrong, what symptoms are you having :)
P.S. the very LAST thing you should do with a 2e2 is fiddle with any screws or levers!
Offline keithyboy
« Reply #4 on: 22 June 2006, 13:34 »
I have a strange problem with the way the carb is mounted in that there is a lot of movement to the extent that the front of it will pull clear of the mounting flange and the car will cut out. The wierd thing is that the bolts are all tight.
I don't know if the mounting flange is loose or what so I need to get the carb off and have a proper look and replace the gasket etc at the same time. The problem is that I haven't got time to do it this weekend so I wanted to just jack the idle speed up as a temporary fix to stop it stalling at junctions etc.
I also need a shopping list for when I fix it. Gasket between carb and flange is obvious but is there another one between the flange and the inlet, and does the inlet have to come off to get the flange off? It looks to me like it does.
« Reply #5 on: 22 June 2006, 13:40 »
one thing you could do is unplug one of the the vacuum hoses to the 3/4 point unit, this will raise the idle as the plunger will be stuck out all the time.  I don't advise driving it with an air leak that size though :shocked:
There is only 1 carb -> inlet flange, which is just bolted on, no need to remove the inlet :)
Wait, we are talking about a 1.6/1.8 carby MK2 right?
Edit: I think actually if you simply unplug the TTV the 3/4 will stick open...  Its all on that diagram in the link above anyway, including vacuum hose diagrams down the bottom.
« Last Edit: 22 June 2006, 13:44 by rubjonny »
Offline Daddycool
« Reply #6 on: 22 June 2006, 13:53 »
Is is the rubber flange that the carb is bolted to? as mine perished & split so you could just lift the carb off!!! the only thing holding it on was the airbox!! After this was fixed the carb started behaving it was £40 for a new one from VW.
« Reply #7 on: 22 June 2006, 14:02 »
Yeah IIRC the flange is bolted to the inlet, and the carb then bolts to the flange.  Its been a LONG time since I last looked at a carby though!
Offline keithyboy
« Reply #8 on: 22 June 2006, 15:10 »
That sounds like exactly the problem I've got. Did you have to remove the manifold to replace it?
Offline DogDay
« Reply #9 on: 28 June 2006, 14:56 »
Whats the part# for the rubber block on a '89 1.6 driver?
DD :cool:
Bow Chikka Wow Wow
