Author Topic: Radio Signal  (Read 5946 times)
Blue MK2
Radio Signal
« on: 12 December 2003, 22:14 »
MK2 Golf / Wing mounted antenna
I rewired my sony headunit for some quality cable but now i cant recieve radio signals?
Is this antenna connected to the remote wire on the sterio? if so how?
Any ideas peeps?
thanx in advance
« Last Edit: 12 December 2003, 22:14 by Blue MK2 »
mrwotto
Re:Radio Signal
« Reply #1 on: 12 December 2003, 22:40 »
the remote cable which is normally orange, is used to control either a electric antenna or an amp, basically it turns the power on to either deviced when the head unit is turned on, so i doubt that is your problem, just make sure the connections ar clean and intact, and securly fitted
Blue MK2
Re:Radio Signal
« Reply #2 on: 12 December 2003, 22:44 »
yaeh checked all that stuff. I only get a signal when i touch the antenna ???
mrwotto
Re:Radio Signal
« Reply #3 on: 12 December 2003, 22:51 »
Maybe an earthing problem  ??? as u may be earthing it hwen u touch it
so make sure you got a good earth, not sure how ya can do it with a atenna, maybe run a cable from it to an earth point??
May be worth a go
Blue MK2
Re:Radio Signal
« Reply #4 on: 12 December 2003, 22:55 »
kool :) Ill give it a go on sunday as its gonna be bright and sunny
Blue MK2
Re:Radio Signal
« Reply #5 on: 19 December 2003, 14:33 »
Do you recon i can run a wire from my headunit ariel socket and connect it to earth? Is it possible? ???
Blue MK2
Re:Radio Signal
« Reply #6 on: 20 December 2003, 00:01 »
sorted it ;D
