Author Topic: proportional valve?  (Read 4248 times)
Offline dibdub
proportional valve?
« on: 10 December 2003, 21:40 »
hi new to volkswagen scene. need some help in question if anyone can help.any help appreciated!what is the proportional valve/load sensing valve on a mk 2 golf 16v braking sytstem?   might sound stupid but havnt a clue and car failed mot by it? :'(  where bouts is it located?is it easy fix?and is it dear to buy?any help again is appreciated and thanks in advance for any.
Blue MK2
Re:proportional valve?
« Reply #1 on: 10 December 2003, 21:43 »
Has your car been lowered mate?
Offline dibdub
« Reply #2 on: 10 December 2003, 21:47 »
no,got 16inch wheels on it if that makes any difference?
Blue MK2
« Reply #3 on: 10 December 2003, 21:51 »
im no expert to that sort of stuff but it sounds like a sensing device that senses the rear weight of the car and adjusts the braking to this. ???
Im sure someone will come up with an answer later on. hold tight ;)
golfvr6
« Reply #4 on: 10 December 2003, 21:51 »
The proportioning valve or brake pressure regulator limits the flow of brake fluid to the rear brakes depending on rear axle position. This is to prevent the rear wheels locking up before the fronts when under heavy braking.
What did it fail on exactly? seized valve?
Offline mk1
« Reply #5 on: 10 December 2003, 21:51 »
Hi dibdub.
The valve is a load compensating valve for the rear brakes, the more that you load up the car, the lower it will sit and there is a spring on the rear axle that is connected to the arm on the valve. The spring pulls the arm alowing more brake pressure to the rear brakes and more braking effort. Located on the n/s/r of the car, 4 pipes on it. Probly siezed, drown it in wd40 or similar, and work the arm back and forward. Check opperation by getting someone to press the brakes and the arm should move.
Steve.
Offline mk1
« Reply #6 on: 10 December 2003, 21:53 »
Ah, vr6. Beat me by 22 seconds ;)
Steve.
golfvr6
« Reply #7 on: 10 December 2003, 21:54 »
I had a mk3 1.4 recently that failed the MOT on a seized pressure regulator. The MOT states that the lever on the valve must move freely. As Steve says use WD40 and work the valve lever with a big pair of grips. What works even better is to whack it with a rubber mallet.
golfvr6
« Reply #8 on: 10 December 2003, 21:55 »
Steve.
Repect to Steve, he knows his oats  ;) ;) :) :D
Offline dibdub
« Reply #9 on: 10 December 2003, 22:00 »
 thanks for the help i try what you say 2mo onit?  it might be ok, dunno ?with some garages so i thought id post to find out more bout it.cheers
