The garage
proportional valve?
Topic: proportional valve? (Read 4279 times)
golfvr6
Guest
Re:proportional valve?
Reply #10 on:
10 December 2003, 22:02 »
If the valve is just seized then you should be able to unstick it. Just spend plenty of time hitting it with a rubber mallet!
richandhazel
Global Moderator
Forum addict
Reply #11 on:
11 December 2003, 12:42 »
Hopefully what the guys have said will work as they aren't that cheap..........
Zoid
GTI forum regular
Reply #12 on:
14 December 2003, 15:52 »
does that mean you need to adjust the valve if the car is lowered?
richandhazel
Global Moderator
Forum addict
Reply #13 on:
14 December 2003, 15:54 »
I would have thought so........
golfvr6
Guest
Reply #14 on:
Depends how low you go!
The garage
proportional valve?
