Author Topic: Crank & Cam position sensor  (Read 8072 times)
Say bye bye
« on: 31 May 2006, 16:23 »
Does any one know where this is on a 1.8T aum??? bloody fool who done my cam belt dont seem to have put it back right or may by dirty need to give it a quick check.
This was the error
17748
P1340
Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence
Offline New Duncan
Re: Crank & Cam position sensor
« Reply #1 on: 01 June 2006, 00:11 »
How did he manage to get the Golf back to your house ? Does it run ?
 In the meantime, I will ask my technician. Timing and fitting of cambelt requires comprehensive equipment to get the setting just right, for the turbo models in particular. I don't believe it is a question of wiping the dirt off.  You don't give this job to a fitter  !
I will do dismantling work, my qualified tech guy does the real business.
Duncan
BMW 325 Coupe Sport, Lux pack, Alpina manifold & throttle bore - Cosmo
VW Golf Mk4 1.8 turbo - Silver - AUM / ko3s
Say bye bye
« Reply #2 on: 01 June 2006, 16:30 »
Car has been driving fine (touch wood!!!!) no miss fire/loss in performance or anything, belt is on ok just the sensor is throwing up a fault. Had it done around 2 months ago, bloke who done it is on hols at the mo.  :sad:
Offline Phil_M
« Reply #3 on: 01 June 2006, 21:18 »
Have you tried clearing the codes, it might be due to the fact the sensors were disconnected.
Phil
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
Say bye bye
« Reply #4 on: 01 June 2006, 21:23 »
Ive had the codes cleared, they just come back up after coupla days, then they go off after few days, on again after that etc!!!thats why im thinking might have some dirt? or maybe not aliened properly. Thing is i cant notice any performance loss  :undecided: so im hoping the cambelt change went ok!!
Offline kniterider
  • had most, sold most and often buy more!
« Reply #5 on: 03 June 2006, 22:01 »
i got this problem on my 20v golf gti after a cambelt/engine rebuild... it was due to the inlet cam being one tooth out of time causing the hall sensor to pick up out of time with the rest of the engine... easyily done i got my engine running after rebuild but wasnt 100% right.. id get cam timing double checked (two poitns on cams when at tdc to make sure...) if they are ok i have a spare 20v hall sensor (fits on head) u can have for free if you pay the postage just to try... and send me ypour old one back if it cures it... if not send me mine back...
 :smiley:
Say bye bye
« Reply #6 on: 04 June 2006, 13:06 »
Is it the sensor that fits on the head just under the AUM sign??
