Author Topic: Refurbishing Alloy Wheels  (Read 1198 times)
Offline chappers02
« on: 29 May 2006, 17:12 »
Hi,
Can anyone give me an idea how much it would costs to get some BBS split rims refurbished. They're the 16" MK4 ones.
Thanks.
Offline jv
  • Administrator
Re: Refurbishing Alloy Wheels
« Reply #1 on: 29 May 2006, 18:53 »
150-200 ish
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline wag,en,volks
  • I make wheels shiney ,pm for quotes
« Reply #2 on: 29 May 2006, 19:16 »
depends if you split them down yourself ,and what finish you require (painted, polished ,powder coated ?)
are they curbed / bent ?,
Offline chappers02
« Reply #3 on: 29 May 2006, 19:39 »
Thanks for the replies - atleast it gives me some idea.
I think I'll sick with the diamond cut rim & standard finish for the centre.
They're not curbed - just the usual problem with water under the laquer on the rim.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 29 May 2006, 23:52 »
Get your rims re-cut, but dont have them re-lacquered! Its much better to keep on top of them with autosolve every couple of weeks! in bad weather give them a shot of WD40, to  stop them oxidising, in the winter a light coat of vaseline works wonders :smug:
Tom
Offline chappers02
« Reply #5 on: 30 May 2006, 19:23 »
Do u mean just send the outer rim away? Guess that would be cheaper! Will ask around for a few quotes!
Offline Thom89
« Reply #6 on: 31 May 2006, 00:34 »
If your wheel centre's are OK.. just have your outer rims done! to polish properly they have to come apart anyway, paint stripper the lacquer off, and carefully sand out any corrosion, using increasingly finer grades of wet/dry, then finish with autosolve... its all about elbow grease! thats if your keen :rolleyes:
Or, get them split down, and take the rims to a local metal polisher (generally, people that do electro plating) you could save yourself a fortune! thats if you want a chrome look! if you want diamond cut, then you really have to go down the specialist route. expect to pay £40-60 +vat per rim, anything less is a bonus! These are just a couple of options available,
Tom
Offline chappers02
« Reply #7 on: 31 May 2006, 21:40 »
Thanks for the advice - will ring around for some prices!
