Author Topic: 16 valve gearbox to an 8 valve?  (Read 1002 times)
Offline Simpson
  • one day il learn
« on: 23 May 2006, 19:56 »
ok so i have been searching for quite a whiel and cannot find anything which suggests replacing this on an 8 valve. My mate has a good 16 valve box from a d- reg valver, i was wondering whether to use his clutch and box on my 8 valve as my box is goosed? any ideas whether it is worth it? surely i would get better cruising fuel economy in fifth? as it would rev lower? cheers?  :smiley:
i must buy a new car!
Offline Agreeable Slick
  • Unit
Re: 16 valve gearbox to an 8 valve?
« Reply #1 on: 23 May 2006, 20:04 »
the 8v box is better cruising box. Nothing to say it cannot be done, but you will not gain anything from it.
« Reply #2 on: 23 May 2006, 21:13 »
It will fit fine, all you need is a 16v clutch kit and possibly a 16v flywheel although I'm 90% sure they are the same.
The only difference if its a 2y box is 5th gear is slightly shorter so you have higher revs when motorway cruising, and nthe input shaft is larger (which is why you need a 16v clutch kit)
Offline Simpson
  • one day il learn
« Reply #3 on: 23 May 2006, 21:27 »
ah right i wont bother then, i thought it would be the other way round, cheers lads  :smiley:
