Author Topic: Door Adjustment  (Read 8848 times)
Offline Neil Horn
Door Adjustment
« on: 06 December 2003, 09:43 »
The common prolem of door bottoms starting to rub on the slls.  How easy is it to replace hige pins/adjust doors.  I am afraid f wrecking more than I fix.  Haynes comic jst says " Put em back on, adjust them and Roberst's your mothers Bruvver".  Any better advice/books/websites? >:(
Offline Neil Horn
Re:Door Adjustment
« Reply #1 on: 06 December 2003, 09:45 »
Wow, I've just read my post, how many letas did I mis, tok abut spilling arrars!
Offline dan
Re:Door Adjustment
« Reply #2 on: 06 December 2003, 15:55 »
Quality!
I have the same problem too on my Cabby nearside door, and you are right about the Waynes (Sorry Haynes) book, useless.
Offline Gambit
Re:Door Adjustment
« Reply #3 on: 10 December 2003, 15:52 »
put a wheel stud in the bottom bracket of the door and gently close it, this will lift the door upward by resetting the sag in the bracket
dont close it too hard or it will over correct it
if you over correct it then still the wheel stud in the top hinge and this will lower.
just take it slowly bit by bit, checking after each squeeze!
Offline richandhazel
Re:Door Adjustment
« Reply #4 on: 10 December 2003, 16:37 »
Do you know.........I knew there was a fix for this but I couldn't remember what it was, must be getting old. Well done Gambit.
Offline Neil Horn
Re:Door Adjustment
« Reply #5 on: 10 December 2003, 20:57 »
That's tomorrows job sorted.  I'll let you know how it goes.
Cheers.
Offline Neil Horn
Re:Door Adjustment
« Reply #6 on: 10 December 2003, 21:15 »
Gambit,
You da man!!!  Why wait 'til tomorrow, that took about 5mins.  Had an M10 bolt in the garage, found that worked a treat.  Door opens and shuts as smooth as silk now.
 ;D
Offline miguel
Re:Door Adjustment
« Reply #7 on: 11 December 2003, 09:59 »
sorry i'm lost! where in the bracket? which bracket? can you post a picture of said bolt in said bracket?? ??? ??? ???
Offline Gambit
Re:Door Adjustment
« Reply #8 on: 11 December 2003, 10:25 »
no pics sorry.
open your door wide, you will see two brackets/hinges holding the door onto the body
put(hold) the wheel stud in bottom bracket so that when you close the door over the wheel stud is trapped in the bracket, and gently tug the door. open the door remove the wheel stud then test to see how much it has lifted
repeat until u get it perfect
like this
/\ = door hinge
* = wheel stud
« Last Edit: 11 December 2003, 10:29 by Gambit »
Offline troublesome51
Re: Door Adjustment
« Reply #9 on: 22 November 2005, 14:16 »
i know this is ages after its been posted, but i need o do this fix on my drivers door as its dropped slightly.
Can someone give me a bit more detail i dont understand whre to put the wheel stud (oh and what is a wheel stud)
cheers guys
Just realised MK1 ive got an MK4, is it the same??
