Author Topic: golf woes,,,mk3, 8valve  (Read 1184 times)
Offline fastrhino
« on: 15 May 2006, 18:20 »
I have been having problems with my golf, I took it to a mechanic mate to have the brakes front and rear done, new wheel bearings in the rears.
problem 1  when the rear brakes have warmed up, after say 3 or 4 miles they squeel really bad, untill you apply the foot or hand brake.
problem 2  when you apply full lock the front starts grumbling (offside) this is only at low speed,,,my mechanic assures me a wheel bearing is needed,,,i am right to be sceptical?
problem 3 when you accelerate sometimes it feels like it is dying, or to put it another way running out of fuel,,although there is plenty of fuel in,  it is intermitant and with a down change and a bit of reving it picks up again,,the only fault i can see under the bonnet is a split in one of the breather pipes off the crank case.
the car does not seem as resposive as it should, this is my first golf so i don't know any better, but i feel it should pick up and rev better than it is at the moment,,,the oil and water are fine.
mick
« Last Edit: 15 May 2006, 18:26 by fastrhino »
Offline inthecity77
Re: golf woes,,,mk3, 8valve
« Reply #1 on: 15 May 2006, 18:55 »
the breather pipe coould cause that alone dude.
do you hear any whistling noises when you boot it?
I had this problem pre-service and it was the breather pipe totally split open.
Im sure the service has helped too but it pulls like a train now!
Judderi
« Reply #2 on: 16 May 2006, 08:38 »
The squeeling brakes might go away after they have bedded in properly. Failing that he might not have re fitted the shims that hold the pad secure.
And the runbling is most likely your front wheel bearing. It may have been close to failing then with all the movement of fitting new disks it has finally given up.
