Golf mk1
anyone got a clue
Topic: anyone got a clue (Read 2712 times)
golfdaw
anyone got a clue
10 May 2006, 08:16 »
does anyone know why my mk1 golf won't start from warm for the last couple of days the car has started as normal first turn of the key in the morning then i drive twenty miles stop at shop to get paper and try to start car to no reply it just keeps firing but won't run. Now i just put it through full service plugs leads distributer filters engine flush so its got me confused doesn't feel like its a problem with the ignition as it keeps trying to turn car over help would be very much appreciated as i am goosed garage down the road couldn't even find anything wrong
gibby
Forum addict
Champions of Europe,ooh ,just the five times then!
Re: anyone got a clue
10 May 2006, 11:34 »
What mk1 is it ? GTI ? If it's an injection mk1 then the prob could be your fuel relay.
I've had the same problem on mine a few times where it starts but after it's run for a bit I've stopped and it wouldn't start so I sandpapered the connections on the relay and then it fires up ok. Does it start up ok after a delay in trying for say 10 or so minutes ?
......now officially dubless.
Neaty
Forum addict
10 May 2006, 11:37 »
^^ look at that, makes his comeback then is straight in to the thick of it with some techincal help, brilliant.
golfdaw
10 May 2006, 11:40 »
its the mk1 1.8 valve gti it normally starts if you keep the key turning till the battery runs near flat pain in the arse as when you put jump leads on it starts after a bit i'll have a look at the fuel relay cheers pal
gibby
Forum addict
10 May 2006, 11:46 »
This is how I know mine had the problem as when you turn the ignition on I can hear the fuel pump prime (back wheel, drivers side), if the relay is the problem then you will not hear the pump prime and so it will not start. This is not a hard and fast rule as I've also read that not everyone can hear their fuel pump prime. This is a good site for some help too, it's mainly for the cab but it may assist you -->
http://dana.ucc.nau.edu/~kaw5/electrical.htm
If it's not that then I'm not sure buddy.
Madone_si
Seattle WA, USA and Middlesex, UK
10 May 2006, 14:15 »
I remember reading in Golf+ mag last month someone asked 'The Brain' the very same question - I'll get the reply for you later tonight...
The Brain is C&R Enterprises - link is on this sites main pageÂÂÂ
http://golfgti.co.uk
Link to the Brain questions and answers are also at The Golf+ mag website -
http://www.thegolf.co.uk/content/ask_brain.htm
- looks like they have uploaded this months questions and answers, thus not showing the answer.
Last Edit: 10 May 2006, 14:17 by Madone_si
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
hairyarse
GTI forum regular
Reply #6 on:
10 May 2006, 16:27 »
Could be cold start valve leaking?
Check out MK1 owners club
www.vwgolfmk1.org.uk
People are posting all the time with the same problem so you'll probably find the answer there!
Andy
golfdaw
Reply #7 on:
10 May 2006, 17:30 »
cheers for all the help lads going to have at a look at a few of those options onight i'll let you know how i get on cheers
Phil303
GTI forum regular
Reply #8 on:
12 May 2006, 15:44 »
...or the ignition timing and/or dodgy vacuum pipes?
Mine was pretty bad as well but once I cleaned up all the starter motor and electrical connections and had the timing sorted, it's as good as new and starts first time, every time.
RYoungMK1GTI
GTI forum regular
Mk1 Golfs R still the Best
Reply #9 on:
12 May 2006, 15:56 »
check the fuel relay, but also the cold start sensor, check its working properly is it runnin ok fuel wise getting decent mpg, some times keep the cold injector open and over fuel when trying warm starting.
Golf mk1
anyone got a clue
