Author Topic: MAF SENSOR - TORX BIT?  (Read 3199 times)
Say bye bye
« on: 07 May 2006, 17:15 »
What size/name of the torx bit do i need to unscrew the maf sensor?? the ones i have dont fit.
Offline richandhazel
Re: MAF SENSOR - TORX BIT?
« Reply #1 on: 07 May 2006, 18:01 »
If you're looking to replace it, you don't need to undo the torx bits. The MAF sensor comes as a complete assembly. Just undo the two jubilee/spring clips and disconnect the connector.
Offline GolfGL
« Reply #2 on: 07 May 2006, 18:55 »
Isn't it a security torx bit probably T15 just get one of them cheap sets that have the bit attachments. But like richandhazel said you dont have to remove the sesnor although it is quicker.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Say bye bye
« Reply #3 on: 07 May 2006, 19:19 »
Want to give it a clean... not sure it is the maf sensor thats gone, when the engine is running and i disconnect the plug the idle speed goes down a bit then goes back up....
« Reply #4 on: 07 May 2006, 19:25 »
In that case, yes you need a security torx bit, not sure what size. I have heard you can knock out the centre spigot but I've never managed it.
Offline Phil_M
« Reply #5 on: 07 May 2006, 19:49 »
Its the T20H you need make sure its got the H on the end or it will not have the hole in.
HTH
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
Say bye bye
« Reply #6 on: 07 May 2006, 19:54 »
Ive kinda gone an ordered this one...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=7614020830&rd=1&sspagename=STRK%3AMEWN%3AIT&rd=1
Right one??  :undecided: looks like the one with the holes in it?
Offline Phil_M
« Reply #7 on: 07 May 2006, 20:11 »
Yep there the kiddies.
Offline GolfGL
« Reply #8 on: 07 May 2006, 22:10 »
Not sure if a clean is a sure fire sign as i cleaned mine and no difference but new one is a big improvement on performance.
« Reply #9 on: 08 May 2006, 09:03 »
Cleaning mine didn't help at all, still failed the VAGCOM test. Had to bite the bullet and replace it.
It certainly won't hurt to try, there may be debris on the hotwire. What usually happens is the hotwire deteriorates due to particles in the air constantly bombarding it. Because of this, it is a very important to ensure you replace the air filter as per the service schedule, more frequently in dusty environments.
