Author Topic: help im confused (its not hard)  (Read 1579 times)
Offline scunny-gti
  • bang on
« on: 01 May 2006, 17:23 »
ive an 89 gti valver and tryin to put my head unit in and have twelve wires popping out so here goes
i believe these to be the power
4 thick wires-
red
pink
brown
brown white
yellow white
blue green
blue
red green
blue green
red brown
blue brown
black brown     these i believe to be the speakers
my question is what the feck are the 4 power ones ANY HELP WILL BE SERIOUSLY HELPFULL CHEERS IN ADVANCE
u can cook, u can f*ck, u can do the washin up, now ive had enuff,come on,f*ck off,get stuffed........................macc lads,great.
Offline Uruk Hai
Re: help im confused (its not hard)
« Reply #1 on: 01 May 2006, 19:16 »
O.K the wires on mine are differant colours to yours but they must do the same things so here go's !
One wire will be permanant live, one will be earth, one will be ignition live and one will probably be for the head unit display dimmer. Get your self a live tester if you haven't allready got one and put one end on the brown wire (that should be earth it is on mine) and then put the other end onto one of the other 3 wires, if it makes a live circuit without the ignition on then you've found the permanant live. If it doesn't make a circuit then switch on the lights or the ignition, if its the dimmer it'll go live when the lights are on and if its the ignition live then it will only make a circuit with the ignition on.
