Author Topic: Whining noise - Any ideas???  (Read 1855 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« on: 30 April 2006, 22:34 »
When I got stuck in the tailback on the M40 on Friday, I noticed for the 1st time, a whining noise when I gently let the clutch up to move off (1-1.5k revs).
(It's a bit like a shot wheel bearing noise, but if it was that, then I'd feel a shake through the steering wheel, & I don't think it would only make the noise at those revs???).
I've been keeping an *ear* out for it ever since, & it appears to only happen when the car has been well warmed up.
Anybody have any ideas?  Cheers.
« Last Edit: 30 April 2006, 22:45 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline GolfGL
Re: Whining noise - Any ideas???
« Reply #1 on: 01 May 2006, 20:47 »
Clutch release bearing or cable maybe.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline richandhazel
« Reply #2 on: 02 May 2006, 16:21 »
If it only happens when you press the clutch then yes, it will be the clutch release bearing.
« Reply #3 on: 02 May 2006, 20:13 »
It's more like when I lift up the clutch to pull off??
Offline Agreeable Slick
  • Unit
« Reply #4 on: 02 May 2006, 20:18 »
If it is the release bearing then you will be able to hear it from startup. I.E> depress the clutch and it will go away. Release it and it will come back until the clutch engages.
Sounds more like it could just be one of the belts slightly slipping when load is applied or the clutch "riding" I.E> rubbing against each other and not catching.
