Author Topic: Problem with my new motor  (Read 1002 times)
Offline GTI999
« on: 27 April 2006, 12:19 »
Hey all,
Brought a 97 P reg GTI 8V a few weeks ago, first vw i've had and i'm well impressed with it.
Got abit of a problem tho:
Its abit juddery when driving along and has cut out a few times. It also nearly did it once when i was driving on the motorway, the rev counter went tits and the oil light lit up but i dropped it down a gear and kept it running luckily!
This morning when i went to go to work I fired it up and it would start up, go to 1000 revs and then drop straight to 0 revs and cut out. It done this 5 or 6 times before it fired up and was ok??!!
Any ideas whats could be up?
Offline adyh
Re: Problem with my new motor
« Reply #1 on: 27 April 2006, 12:45 »
Check the stickey posts . Normal Mark 3 stuff to try .
Clean the Throttle Body
Change the Fuel and ECU Relays .
Offline GTI999
« Reply #2 on: 27 April 2006, 13:29 »
Ok cheers mate, will have look through them. Just thought it seemed abit worse than just being a relay but worth a try!
