Author Topic: golf mk1 gti 1.8 turbo  (Read 1077 times)
Offline DanGtd
  • Mk2 Golf GTD
« on: 23 April 2006, 13:08 »
I have a mk1 golf gti campaign1.8 and access to a 1.8 turbo engine with ko4 turbo at a reasonable price the thing is i need to know what needs to be changed/modified to get the engine running in the mk1 (i dont think getting the engine in should be too much worry as the blocks are near identical) any help would be much appeciated its just i dont want to get the engine and not be able to get it going without great expense.
Mk1 Golf Gti campaign in Mars Red(16 sec Quarter mile)
Mk2 Golf Gti in Tornado Red
Offline golfyjammer
  • www.vag20v.net
Re: golf mk1 gti 1.8 turbo
« Reply #1 on: 23 April 2006, 19:17 »
it will be quite pricey, mainly depends what the engine comes with and what managment you are going to use?
Built by Germans, Thrashed by the English!
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 23 April 2006, 23:38 »
the AEB coded engine from the passat is the easiest to install due to the position of the engine mounts. The other variants can be fitted, but more work is involved in the mounting dept.
Mk4 Golf 150PD
Offline DanGtd
  • Mk2 Golf GTD
« Reply #3 on: 24 April 2006, 17:28 »
thanks for the help so far have contacted jbs who said they can supply engine and everything for £7000 drive in drive out hahaha. is it much cheaper to put in a mk2 as i have a j reg 8 valve digifant i could slot it in and maybe put the digifant in the mk1
