Author Topic: head/valve diagram  (Read 1608 times)
Judderi
Re: head/valve diagram
« Reply #10 on: 21 April 2006, 11:02 »
same thing, make sure the caps all go on the same way they came off :)
Yeah but how do you make sure you get the orientation right and the chain on correctly? Is there a tdc notch or something to line them up to?
Offline Gambit
« Reply #11 on: 21 April 2006, 11:11 »
yes there is two markers on the cam chain sprockets. they need to be facing each other
the cam belt end has a TDC marker. when this is TDC the sprocket marker on the other end is at 3'o'clock you then set the other cam sprocket marker to face it at 9 o'clock
« Reply #12 on: 21 April 2006, 20:05 »
or if you're worried, make your own markings with some tipex or someting, lable them 1-5 and put an arrow pointing to the cam sproket end of the engine ;)
