Golf mk2
head/valve diagram
Topic: head/valve diagram (Read 1607 times)
rowlers
I'm back - MK7 GTI
head/valve diagram
19 April 2006, 18:39 »
maybe thick but which is the "Hydraulic tappets" on here? or are they in a completely different place altogether??
please enlighten me!
Last Edit: 19 April 2006, 20:33 by rowlers
takethefifth
Re: head/valve diagram
19 April 2006, 22:38 »
Hmmmm not any of them things! I think hydraulic lifters is what they are called, they should be with the cams like.....
They go between the cam and the valve push rod and extend so they touch the cam thus extending more when they get worn. and extending less when thye havn't got sufficient oil pressure causing tap on startup.
www.tt5th.co.uk
AudiA8Quattro
Forum addict
19 April 2006, 22:41 »
Hydraulic tappet is no.8.
takethefifth
20 April 2006, 00:11 »
Is that what it looks like?!?
I must admit i always wondered!
Sorry for the misleading reply. Getting ahead of myself i'm afraid :embarassed:
www.tt5th.co.uk
silkyballs
more tea vicker??
20 April 2006, 00:17 »
some peeps call them followers just put a new set in mine and theyre suprisingly cheap!
http://
[img]
Judderi
Guest
20 April 2006, 14:26 »
Gonna hijack a little here. When you take your cams out, how do you know your putting them back in right? Do you line marks up or something?
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #6 on:
20 April 2006, 15:23 »
Just mark which valve they all came from, as well as the cam caps. Make sure you get the order and orientation of the caps exactly right or you'll turn the head & cam into scrap!
Judderi
Guest
Reply #7 on:
20 April 2006, 15:29 »
what if your fitting new cams?
rubjonny
10k hero
Reply #8 on:
20 April 2006, 15:41 »
same thing, make sure the caps all go on the same way they came off
rowlers
I'm back - MK7 GTI
Reply #9 on:
20 April 2006, 19:28 »
did finally work it out, why are they called so many different things?? Do you reckon I should fit 16 new tappets then? Can you tell if they are worn? and if so should I just replace those that look dodgy?
Golf mk2
head/valve diagram
