Author Topic: mk1 rear axle  (Read 1797 times)
Offline golfdaw
mk1 rear axle
« on: 16 April 2006, 20:32 »
wondered if anyone could help i recently hit a kerb with mk1 and bent the rear axle i have since been offered a rear axle with a disc conversion apart from the obvious need for calipers would i need anything else or is it a straight forward swap also what calipers would be the best choice hope someone can help cheers neil
Offline richandhazel
Re: mk1 rear axle
« Reply #1 on: 29 April 2006, 00:37 »
Are you sure its so whole subframe you need :undecided:
Would have thought that any damage would be to the stub axle which is bolted onto the rear subframe. Fairly cheap to replace..........like for like.
Offline mexicorich
Re: mk1 rear axle
« Reply #2 on: 12 August 2006, 21:40 »
They are not subframes thay are axles. The stubs are very hard. Certainly I have slid a Mk1 and bent a back axle before. It was obvious looking at the fillet between the beam and trailing arm that there was a kink there. If like mine, your stub axle is Ok, you could swap your drum set up over to your replacement axle if you wanted to
Re: mk1 rear axle
« Reply #3 on: 13 August 2006, 16:27 »
You would need scirocco 16v handbrake cables, and early MK2 rear calipers.  Possibly later ones would fit but I'm unsure if the handbrake cable would reach...
Re: mk1 rear axle
« Reply #4 on: 13 August 2006, 23:43 »
Yes you are right, so sorry. I guess they knew what I meant. 5/10 must try harder :angry: , thay or they if we're going to be so picky :nerd:
« Last Edit: 13 August 2006, 23:48 by richandhazel »
