Author Topic: Inner arch grinding on CV joint! Any solutions?  (Read 4266 times)
Offline lowgolf
« on: 28 November 2003, 14:33 »
I am currently having a problem, i have got my car to a height that i think looks nice, but my O/S CV joint is catching on the inner arch, is there any way in stopping this without grinding out the inner arch or has anyone come across this problem before
<br /><br />Yeah!!!
Offline lowgolf
Re:Inner arch grinding on CV joint! Any solutions?
« Reply #1 on: 28 November 2003, 14:59 »
I forgot to say its lowered 105mm on 15's, with avo coilovers
<br /><br />Yeah!!!
Offline sKrEwBaLL
« Reply #2 on: 28 November 2003, 15:11 »
That sounds LOW
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 28 November 2003, 16:59 »
a visit from the angle grinder should sort it ;D
Blue MK2
« Reply #4 on: 28 November 2003, 17:46 »
 :o your car sounds 2Low4AFatHoe :o
Angle grinder. make sure you cover the metal work up after
kniterider
« Reply #5 on: 28 November 2003, 18:40 »
yep sounds like a grinder job to me, must be mega low to rub cv joints, mind you mines quite low and makes a 'rub' noise, will have to look into it as mine aint catchin any arches etc!!
Blue MK2
« Reply #6 on: 28 November 2003, 19:07 »
its still abit dangerous isnt it? ???
Offline mk1
« Reply #7 on: 28 November 2003, 19:37 »
Quote from :  lowgolf
my O/S CV joint is catching on the inner arch.
Ehh?. Please I dont understand.
Steve.
golfvr6
« Reply #8 on: 28 November 2003, 23:45 »
Steve.
Thats what i thought mate, how can that happen? can you post a pic please.
Offline modulater
« Reply #9 on: 29 November 2003, 21:18 »
I didnt think the CV joint could be rubbing as they are either attached close to the gearbox or the hub. You would have to move the gearbox to make them rub.
I think its more like the driveshafts are rubbing the inner arch and with a drop of 105mm I am not suprised.The torque steer effect from that must be immense and I would be suprised if your CV joints last that long as the angle of the shaft affects the way on which the force operates on the joint.
how much of an angle up do the driveshafts have?
