Author Topic: Standard unleaded or 97 high octane?  (Read 3002 times)
Offline Nick16valve97
« on: 11 April 2006, 15:27 »
Hi all - what do you all use re fuel? - and if I use high octane which takes more care of my engine with better performance, is there anything you have to alter on the engine or is it a case of fill up and that's it?
Offline Overseer
Re: Standard unleaded or 97 high octane?
« Reply #1 on: 11 April 2006, 15:30 »
just fill it up.. the knock sensor takes care of the rest..
i used to run on optimax.. but after the last big price hike i've not stepped back up from normal fuel..
Offline inthecity77
« Reply #2 on: 11 April 2006, 16:47 »
Anyway, I think the 8v motor is so much old technology it would run on a coal and wood mix (only in the correct quantities mind!)
Offline monzablue16v
« Reply #3 on: 11 April 2006, 17:10 »
16v doesn't have a knock sensor does it Overseer?  I use 95 RON as that's what mine was set up to use, if filled with ultimate or optimax it starts to pink so depends on how the car was set up last.
Offline PassRatGT
« Reply #4 on: 11 April 2006, 17:31 »
Amonth ago I would have said it don't matter what petrol you use but after a few tanks of super i've changed my miind
Car feels smoother and I get loads better mpg
Visit the miss's shop www.oohpretty.co.uk click on left
« Reply #5 on: 12 April 2006, 09:15 »
I have a 16 valve 97 - so does anything need adjusting?? and how do I check what it's "set up for"?
Offline AudiA8Quattro
« Reply #6 on: 12 April 2006, 17:17 »
Mk3 8v,16v, and vr6 ALL have knock control.
Offline nosaj26
« Reply #7 on: 12 April 2006, 17:44 »
try filling up at tesco's there super unleaded is 99 octane!!!!
« Reply #8 on: 13 April 2006, 09:54 »
is that good for your car? - can't imagine tesco high octane is? - it's like drinking a fine burgundy or a can or special brew - the special brew will get you lagging quicker, but what on earth will it do to your insides over time??!
Offline adyh
« Reply #9 on: 13 April 2006, 10:47 »
It wont be set for anything . Just put in what you want .
