Author Topic: why do i still get rubbish MPG?  (Read 2113 times)
Offline neilgolfboy
« on: 10 April 2006, 19:21 »
i got a 1600 driver.
i have put on:
-newly refurbed carb (2e2)
-new rotor arm
-new plugs
-new fuel filter
-new air filter
-drilled air box
-new 'o' ring in the inlt mani (wasn't blocked anyway)
-new dizzy cap
the car pulls very well, and drives great, but when it stands after a run, it stinks of petrol. dont smell it inside when driving though. it take ages to catch when warm starting -it just turns over and over. there are no obvious leaks, no pools of petrol underneath.
i got about 80 miles from 20 quid of juice. that aint right is it?
someone suggested the fuel accumulator, but i dont know.
what do you guys think?
Offline VWDino
  • MkII 1.6 Driver. GTi cam, K&N .....
Re: why do i still get rubbish MPG?
« Reply #1 on: 10 April 2006, 20:48 »
Thats very poor MPG. I'd expect around twice that with mine (depending on what type of journey). Is the carb set up properly? You might be running rich?
Offline neilgolfboy
« Reply #2 on: 10 April 2006, 21:35 »
had the co2 checked out it it was all fine.
Offline monzablue16v
« Reply #3 on: 10 April 2006, 22:30 »
Check for fuel leaks again matey sounds like your spilling more than your burning :)
also check all around the tank as a breather may have come of happened on a couple of mates cars not an easy job either :(
« Last Edit: 10 April 2006, 22:32 by monzablue16v »
Offline neilgolfboy
« Reply #4 on: 10 April 2006, 22:39 »
like i said mate, there is no drips on the floor, nor puddles when parked upafter a run.
what do you mean the breather may have come off?
could it be the fuel reservior/accumulator thingy? it smells of petrol at the fron rather than the back.
Offline mk2_singh
« Reply #5 on: 10 April 2006, 22:58 »
you need ecotek valve.
Offline neilgolfboy
« Reply #6 on: 10 April 2006, 23:03 »
please explain all about ecotek valve.
Judderi
« Reply #7 on: 11 April 2006, 08:14 »
Forget about the ecotec mate. 1st you need to get your overfueling sorted.
The ecotect is a daft little gizmo that claims to give better fuel economy. But if theres a problem then that needs fixing before you guy splashing cash on a ecotec valve.
Offline baz_the_man62
« Reply #8 on: 11 April 2006, 10:11 »
if u find the answer let me know mate.. i got a 1300 with weber carb and an ecotek on it and im gettin a crappy 90 miles from 15 quid... and thats not raggin the ass off it either.
Offline DavidGTi
  • The man. The legend.
« Reply #9 on: 11 April 2006, 12:07 »
Do people still use those ecotek things? My god... :shocked:
Take them off your cars for the love of god.
We had this problem with our Mk1 GTi, it may be that a breather pipe from the petrol tank is/has been disconnected or come loose.
You could try running some STP cleaner (Halfords) through your petrol tank...although I'm not sure that would make much difference.
Personally, I'd advise taking it to a VW specialist or a good garage that you know of.
"The distance between insanity and genius is measured only by success" - Carver, E
