Author Topic: Induction kit help please!  (Read 2582 times)
Offline ducatimad
« on: 27 November 2003, 12:44 »
I have just fitted a induction kit to my 1991 8 valve golf gti, Is it a must to have the hot air pipe going to the filter?
golfvr6
Re:Induction kit help please!
« Reply #1 on: 27 November 2003, 14:58 »
No, i wouldn't think so.
Offline jedi16v
« Reply #2 on: 27 November 2003, 15:28 »
try and fix up a cold pipe thats what i did in my 8v i fitted it into the grill. lots of cold air . made a difference
Offline lewis
« Reply #3 on: 27 November 2003, 16:14 »
Hot air doesn?t carry as much oxygen as cold. Cold air has a greater density than hot which is what you want (more oxygen bigger bang)
Jedi16V is spot on with his advice.
golfvr6
« Reply #4 on: 28 November 2003, 13:29 »
The hot air pipe is there to stop the throttle body freezing. That doesn't usually happen much in this country.
Offline ducatimad
« Reply #5 on: 28 November 2003, 19:04 »
Mr Golfvr6, cheers you answered my question - I should have been more accurate in my original forum question! It was the freezing of the fuel that was worrying me! but I will try it without the hot air pipe and see!
Cheers everyone!
golfvr6
« Reply #6 on: 28 November 2003, 23:47 »
The fuel won't freeze , its added just before the inlet. Unlike carbs where the fuel is added earlier. Later cars have a coolant heated throttle body, well mine does anyway!
Offline modulater
« Reply #7 on: 29 November 2003, 22:06 »
Its there because of the venturi effect makes the air charge colder as it rushes down the plenum chamber. In all honesty it has to be bloody cold to get a real benefit from having it there and even then thats why you have a fifth injector.
And its very rare for fuel to freeze. It just drops out of suspension with the air.
Offline ddubya
« Reply #8 on: 29 November 2003, 22:19 »
i ripped the hot air pipe off straght away ,you want cold air for performace! hot air=bad cold air=good.
