Author Topic: Gear selection  (Read 1154 times)
Offline hockeylad72
Gear selection
« on: 04 April 2006, 18:14 »
Help again.
when the car is in neutral should I be able to push gearstick forward and it should go into 3rd gear?
mine seams to want to go into 5th
any ideas
cheers
Davie
Re: Gear selection
« Reply #1 on: 04 April 2006, 22:57 »
if you push the stick forward in neutral it should go into 3rd, if its going into 5th then you need to adjust your linkage, see the mk2 maintenance + info section at the top of this forum :)
Offline hockeylad72
Re: Gear selection
« Reply #2 on: 05 April 2006, 19:31 »
thanks rj
Re: Gear selection
« Reply #3 on: 06 April 2006, 09:31 »
no worries  :cool:
Offline steviem
Re: Gear selection
« Reply #4 on: 06 April 2006, 09:40 »
sorry for the hijack....
but sometimes (ok, when I'm driving a bit quick..), when i change to 2nd gear, the gearstick sometimes twists rather than go straight into gear...
Re: Gear selection
« Reply #5 on: 06 April 2006, 09:43 »
does it happen when cornering?  If so replace the gearbox mount with a 1.3 bonded rubber one.  Also lift the stick upwards, if it moves at all then you need to replace the housing under the car :)
