Author Topic: 89 8v engine mounts  (Read 1281 times)
Offline 84mars20v
89 8v engine mounts
« on: 04 April 2006, 10:40 »
Ok, i know this question gets asked a lot & i have searched around for answers, but more or less every thread points to a differnt way of going about upgrading the engine mounts. Im not really intersted in buying these vibratec mounts as it will work out more than what the cars worth. Do i just go to euro or gfs and get a standard set, or is it a good idea while i am doing the job to use ones of a td/16v/g60, if so which ones? Your opinions are greatly accepted, thanks. Tom
Offline Mirage-
Re: 89 8v engine mounts
« Reply #1 on: 04 April 2006, 11:32 »
I've decided on the following setup - Solid front mount, G60 rear mount and standard Gearbox mount.
May later upgrade the gearbox mount but I'm just holding back at the moment for a 2.0 engine before fitting it all together with the new wishbones, poly bushes, ball joints and track rod ends  :cool: so will let you know how it all feels together (should be in next couple of weeks, newborn daughter permitting)
Regards
Ian
« Reply #2 on: 04 April 2006, 13:30 »
Aye solid front, 16v/G60 rear and bonded rubber gearbox are a good combo for reduced engine movement without excessive vibration.  Mr.Brown on here sells solid front mounts for a bargain price, and visit AVS for the rest:
16v/G60 rear:
http://www.vwspares.co.uk/product_info.php?products_id=1595
Bonded rubber gearbox:
http://www.vwspares.co.uk/product_info.php?products_id=1624
Offline 84mars20v
« Reply #3 on: 04 April 2006, 14:31 »
cheers. Am chasing Mr Brown up....
Offline Nick1980
« Reply #4 on: 06 April 2006, 20:38 »
Sorry, don't mean to hijack, but I think I need at least a new front engine mount too cos the car jumps a fair bit when I come off the power and the engine does seem to be trying to climb out of the bay when I hold it at the biting point!
Thing is, I don't really wanna spend £50 on a solid front mount, I'd be happy with a normal one as long as it stops the jumping etc. Is it worth getting a diesel/16 valve mount or just getting a direct replacement? Probably gonna go to GSF or Volkspares.....
Also, when I look down at the engine mount from above, on the left hand side near the oil filter there are 2 brackets that don't quite line up (although they look like they probably should). Is there supposed to be a bolt through here, cos there isn't on mine? Just thought than might contribute to the excess engine movement........
Come on Jonny, I know you wanna help me  :smiley:
« Reply #5 on: 06 April 2006, 22:30 »
A solid rubber mount is probably worth a try, its what I've got on my GTI :)
http://www.vwspares.co.uk/product_info.php?products_id=1619
As for that bracket, it sounds like there should be a bolt there but I can't picture what you mean, could you take a piccy?
Offline Nick1980
« Reply #6 on: 07 April 2006, 00:35 »
lol, I knew you'd come to my aid dude :grin:
I'll try one of those then - now £17 I can deal with!
I have got a pic, but i can't work out how to attach it - I assume I'm gonna have to set up a photobucket account and link to that?
« Reply #7 on: 07 April 2006, 07:37 »
Yeah you need somewhere to host it online, could email or msn it to me :)
Offline Nick1980
« Reply #8 on: 07 April 2006, 18:28 »
ok mate, emailed you  :smiley:
