Author Topic: kenwood head unit  (Read 2933 times)
Offline theviper
kenwood head unit
« on: 01 April 2006, 22:41 »
i have just been given a Kenwood KDC-W7027 head unit by a friend to fix or bin it so i need help please are any of you any good with radio's ???
if so the problem is  you turn the power on the panel slided out  then after 2 second's slide back in the the power turns off  what could this be ????
pete :evil:
Offline mk2singh
Re: kenwood head unit
« Reply #1 on: 01 April 2006, 22:47 »
does the display come on wen the panel slides out??
Offline theviper
« Reply #2 on: 02 April 2006, 07:20 »
yes both sides light up then when it slide back in it gose all blank again you can push the power buttom straight away and it will do the same i did it about 10 times and the same ever time
pete  :evil:
Offline mk2singh
« Reply #3 on: 02 April 2006, 12:17 »
you could try and change the ribbon cable that connects the back part of the headunit to the slide out panel, they are a common fault on most flip down kenwood headunits. have a look on ebay for it as i bought mine from there. you will need to find out the part number for the cable as there is different types. could be the ribbon cable, if not most likely to be something wrong inside the main box.  :wink:
Offline theviper
« Reply #4 on: 02 April 2006, 21:38 »
is it a hard job to do mk2singh ???  and it is call a front panel ribbon ???
Offline mk2singh
« Reply #5 on: 02 April 2006, 23:22 »
its not that hard to do, u need to locate the ribbon inside the headunit and then follow it to the panel. when the detachable panel is taken off have a look where the connectors are where the fascia connects to, that is the ribbon cable. once you open it up and have a good look how the ribbon is connected and fed to the sliding panel you should knw how it goes together. its abit hard to explain, but just ask me if you get stuck and ill try my best to help you. here is the search results for kenwood rbbon cables on ebay. http://motors.search.ebay.co.uk/kenwood-ribbon_In-Car-Entertainment-GPS_W0QQbsZSearchQQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQfgtpZQQfposZPostcodeQQfromZR2QQfsooZ1QQfsopZ1QQftrtZ1QQftrvZ1QQga10244Z10425QQlopgZQQsacatZ3270QQsadisZ200QQsaprchiZQQsaprcloZQQsargnZQ2d1QQsaslcZ3QQsbrftogZ1QQsofocusZunknown
dont forget to check you are ordering the right part. the part no is printed on the cable near the end that connects to the main board inside the headunit, and make sure you buy one with the connector already soldered on which will save any hassle of desoldering the old and resoldering etc.
Offline mk2singh
« Reply #6 on: 02 April 2006, 23:25 »
but just thinkin, could be something in the main box if the panels all light up n dat. but its worth a try cus ive herd the ribbon cable is a problem on the flip out panle kenwoods. and was same problem on mine
Offline [han]
  • Graphic Designer for Haribo
« Reply #7 on: 03 April 2006, 08:22 »
It should be a warranty part, as we got a guy what appears to be a similar thing a few weeks back! So if it's no longer under warranty then it will cost you (obv) and i think they're about £20 to buy i'dhave thought.
Although there is a guy on Ebay, who sells facia panels (new ones) and as far as i know all you have to do is give him all of the serial numbers and details off the unit and he will send you a new Facia Panel,  Unfortunately i dn't know how much they are!
Offline Dizzie
  • Make friends with your fast
« Reply #8 on: 03 April 2006, 17:56 »
this part is sometimes called a 'flex pcb'
Mk4 Golf 150PD
