The garage
MK2 overheating?
Topic: MK2 overheating? (Read 5620 times)
Blue MK2
Guest
Re:MK2 overheating?
Reply #10 on:
26 November 2003, 21:15 »
wat light comes on again?
ASH
Here all the time
its a way of life!
Re:MK2 overheating?
Reply #11 on:
27 November 2003, 17:43 »
topped it up and it still flashes on and off, after about 7 miles?
its the water coolant light next to the battery light.
really starting to annoy me know!
sKrEwBaLL
Here all the time
Re:MK2 overheating?
Reply #12 on:
28 November 2003, 12:44 »
Mine was doing this, I had to overfill the coolant to stop it flashing. I think I filled it until the expansion tank was about half full
golfvr6
Guest
Re:MK2 overheating?
Reply #13 on:
28 November 2003, 13:44 »
Check the warning switch on the coolant tank with a multimeter.
ASH
Here all the time
its a way of life!
Re:MK2 overheating?
Reply #14 on:
28 November 2003, 19:37 »
ok, could be corroded couldn't it?
golfvr6
Guest
Re:MK2 overheating?
Reply #15 on:
28 November 2003, 23:56 »
Yep , try changing the tank over if you can get a cheap one, or just test the switch for resistance.
ASH
Here all the time
its a way of life!
Re:MK2 overheating?
Reply #16 on:
30 November 2003, 09:26 »
for the mean time do you think i should just go by the guage and ignore the light?
golfvr6
Guest
Re:MK2 overheating?
Reply #17 on:
30 November 2003, 09:36 »
If the coolant isn't boiling up then i wouldn't worry.
modulater
Re:MK2 overheating?
Reply #18 on:
01 December 2003, 01:37 »
Quote from: golfvr6 on 28 November 2003, 23:56
an even easier answer and one you seem to have failed to try is to remove the sender wire from the coolant expansion tank and just bridge the terminals with wire or a paperclip.
does the light still flash?
ASH
Here all the time
its a way of life!
Re:MK2 overheating?
Reply #19 on:
01 December 2003, 23:57 »
sorry bit thick, bridge them on the plug, and the light should come on and stay on?
The garage
MK2 overheating?
