Author Topic: MK2 overheating?  (Read 5529 times)
Offline ASH
  • its a way of life!
MK2 overheating?
« on: 26 November 2003, 16:58 »
The water tempreture warning light keeps flashing on, but the temp gauge sits dead in the middle?
The warning light flashes on when the mfa reads about 124.
any ideas?
just confused that the guage doesnt go into the red?
golfvr6
Re:MK2 overheating?
« Reply #1 on: 26 November 2003, 17:05 »
Is the coolant boiling up? ,  if not then just an electrical fault.
Offline ASH
Re:MK2 overheating?
« Reply #2 on: 26 November 2003, 17:23 »
what temp is too much, is 124  on the mfa ok, or should i relly on the mechanical guage?
golfvr6
Re:MK2 overheating?
« Reply #3 on: 26 November 2003, 17:26 »
The mfa shows oil temp, the dial shows coolant temp. 124 does sound quite high for oil. Does it always go up that high?
Offline Mars Attacks
Re:MK2 overheating?
« Reply #4 on: 26 November 2003, 17:26 »
i thought that the light flashes on the water temp gauge when the coolant level is too low. It may be worth checking your level when the car has cooled down one morning.
golfvr6
Re:MK2 overheating?
« Reply #5 on: 26 November 2003, 17:28 »
Yep, it also comes on when the temp hits the top.
Offline ASH
Re:MK2 overheating?
« Reply #6 on: 26 November 2003, 17:51 »
but the guage reads ok?
Offline ASH
Re:MK2 overheating?
« Reply #7 on: 26 November 2003, 18:28 »
Doh! the MFA shows the oil temp not the water temp.
still no idea why the light flashes.
Blue MK2
Re:MK2 overheating?
« Reply #8 on: 26 November 2003, 18:48 »
Tried topping up the levels, checking for leaks?
Offline ASH
Re:MK2 overheating?
« Reply #9 on: 26 November 2003, 21:10 »
i'll try topping it up.  :)
