Author Topic: mk3 gti 8v loads of problems  (Read 1240 times)
Offline xr3iturbo
« on: 27 March 2006, 20:00 »
hi every 1 another newbee
got a m reg 2l 8v gti 2 weeks ago but few probs   as listed
1.first of all what is the redline on 8v  mine redlines at 5000 rpm(but when moving if i turn the ignition of and bk on it goes all the way to 7 k?????
2.the revs at idle are very unstable???
3.the car has cut out  twice (both times when u put your foot on the throttle its like the ecu is cutting the spark but still adding the fuel, reason i think this is because when i try to start the car again it WONT , so then i pull the fuse for the fuel pump few turns and it will fire.
so i have changed the plugs (but they are black every time u take them out=overfulling?)
rotor arm +cap
looking at doing coil next but need some advice please
thanks alot
tommy :smiley:
Offline Bazzer
Re: mk3 gti 8v loads of problems
« Reply #1 on: 27 March 2006, 20:53 »
Hi and welcome...
All the questions you have have been answered quite recently - check out the search feature...  :wink:
You never know, timing the engine up might just sort the lumpy idle and the limiter too...
Bazzer
Offline xr3iturbo
« Reply #2 on: 27 March 2006, 22:31 »
 :wink: cheers mate
had a look at good few posts  :undecided:
do you know what settings to use on the crank pull and  cam pully
thanks alot for the help
only had the car about fully 3 weeks  so will get manual for it but would be greatful if you could tell me the marks for the timing
tommy
