Author Topic: How do I remove the rear window on the old top?  (Read 1743 times)
Offline Danny
« on: 27 March 2006, 04:05 »
I'm replacing the top soon on my CAB, The instructions on the new top states that i have to use my old window. How do I safely remove the window?
No DuB should die.
Offline Phil303
Re: How do I remove the rear window on the old top?
« Reply #1 on: 27 March 2006, 09:32 »
You'll have to cut the complete window and metal frame out of the roof. Before you go slicing away though, there are two thick canvas straps that run the length of the roof. They are fixed to the top edge of the rear window frame and run the length of the roof. Be careful not to cut through these as you may need to use them in your new roof.
Also make sure you don't damage the rubber seal around the frame.
Good luck!
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #2 on: 27 March 2006, 12:00 »
Very carefully... as Phil as said..
you also might find this useful as well... http://www.golfgtiforum.co.uk/index.php?topic=34662.0
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline Danny
« Reply #3 on: 28 March 2006, 03:52 »
Alright.. Dont cut large straps.. Check. Now once I have removed the glass is it hard to re-install? Do i need to relace the seal? Thanks.
No DuB should die.
Offline Madone_si
« Reply #4 on: 28 March 2006, 12:55 »
No installing the glass is easy, but you need two people and make sure you don't cut away too much of the hood for the window, leave loads and trim once you have the window in place and hood around window frame.
SOLD - BLACK SOY 92
Offline Phil303
« Reply #5 on: 28 March 2006, 18:20 »
I'll second that. The glass, metal frame and rubber seal should ideally be kept as one piece, you don't need to take the glass out the frame. If the seal is in good condition then I don't see why you would need to use a new one.
The hole you cut for the rear window frame will be a lot smaller than the frame itself but as Madone says, you trim away the excess once the frame is in place.
And get a mate to help!
« Reply #6 on: 13 April 2006, 16:21 »
no need to cut anything, you should be able to push/pull it out no problem, came out fine when we replaced the hood on our cabby.  Its only the front screen you have to cut the seal to remove!
The hard part is cleaning off all the old sealant from the seal, takes ages and is one of them horrible boring jobs that last forever :grin:
Good luck, and I hope your rear frame is ok, most of them are rotten right through!
