Golf mk2
Front bumper sagging
Topic: Front bumper sagging (Read 6287 times)
JezGTI
GTI forum regular
24 November 2003, 14:54 »
I have a 91 8v GTI and the front bumper is sagging at the sides. Anyone else had this problem? Can it be corrected and if so how?
Thanks
Jez
Blue MK2
Guest
Re:Front bumper sagging
24 November 2003, 15:05 »
Your bumper clips on the bumper are broken. VAG should have these for next to nothing
JezGTI
GTI forum regular
24 November 2003, 15:31 »
Thanks Blue
Are these easy to fit?
Blue MK2
Guest
24 November 2003, 15:36 »
Yeh I think they are screwed on.
JezGTI
GTI forum regular
24 November 2003, 15:55 »
OK, so the bumper clips are easy to fit to the bumper, but do I need to remove the bumper (or anything else for that matter) in order to do this job?
Thanks again Blue.
Gambit
Forum addict
24 November 2003, 16:08 »
if the bumper clips on the inside of the bumper themselves are banjo'd, i.e. the lugs have been broke then you wont be able to get them from VAG
ill put up a pic in my gallery of what i mean
Gambit
Forum addict
Reply #6 on:
24 November 2003, 16:19 »
in the end i had to get some sheet tin and make new lugs for it
it was just bent into this shape
._
then riveted to the existing broken bracket
hope this makes sense!!
Dizzie
Forum addict
Make friends with your fast
Reply #7 on:
24 November 2003, 18:59 »
mine's the same on 1 side. I really need to sort it out as it knocks now and then on the wing. the brackets that got onto the wing you have to get from VW and they're ?2 something. If you've converted to big bumpers you'll probably have to drill another hole as the larger brackets have 2 points where they attach to the wing. after that they sit really flush against the wing.
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
AL16v
Reply #8 on:
24 November 2003, 21:48 »
Quote from: Blue MK2 on 24 November 2003, 15:36
The brackets clip into holes in the wing, then pins in the holes should stop them coming out. The bumpers should slide over the brackets. On a genuine VAG bumper I think there is some adjustment in the clips on the bumper.
* 94 Audi Coupe 2.6 V6 *
_88 Mk2 Golf GTI 16v_
Mongoose Stainless Steel System
256mm Brake Conversion
Boge Springs Spax Gas Shox
Full Leather
= 99 Bora V5 =
Jazz Blue, totally standard.
Blue MK2
Guest
Reply #9 on:
25 November 2003, 08:11 »
Genuwine Bumpers have moulded in brackets. Well they where on mine. Aftermarket bumpers have screwed in brackets on the bumpers.
Last Edit: 25 November 2003, 08:11 by Blue MK2
Golf mk2
