Author Topic: Front bumper sagging  (Read 6296 times)
Offline Gambit
Re:Front bumper sagging
« Reply #10 on: 25 November 2003, 09:08 »
here are a few pics of mine when the top lug was broke
http://www.golfgtiforum.co.uk/gallery/displayimage.php?album=random&cat=10851&pos=-171
http://www.golfgtiforum.co.uk/gallery/displayimage.php?album=random&cat=10851&pos=-172
unfortuately i aint got any of the new metal bracket that was fixed onto it
« Last Edit: 25 November 2003, 09:10 by Gambit »
Offline JezGTI
« Reply #11 on: 25 November 2003, 11:56 »
Thanks guys, appreciate your help
Will have a good luck this weekend, in order to carry out the necessary repair will I have to remove the bumper?
Blue MK2
« Reply #12 on: 25 November 2003, 12:58 »
yes you will have to remove the bumper.
Unclip the indicators and fogs if you have them.
There are 2 17mm bolts that hold the bumper on.
Look under/up the front of the car, you you will see one bolt on either side.
Once these bolts are off the bumper should pull out nice and easy  ;D
Offline JezGTI
« Reply #13 on: 25 November 2003, 16:48 »
Thanks Blue, will try it this weekend.
Veedubgt18v
« Reply #14 on: 25 November 2003, 18:26 »
one thing the front bumper screws form part of the cross brace that supports the engine if you remove them then your engine is essentially only supported by 2 small bolts on either end of the lower crossmember. so support your engine underneath with a bottle jack and a piece of wood. if you got factory fit bumpers there will prob be some small screws holding the palstics on down the bottom of each wing, undo these as well!  :)
Offline JezGTI
« Reply #15 on: 26 November 2003, 15:32 »
Ah, that's good to know, could have had a bit of a disaster on my hands.  Thanks Veedub.
