Author Topic: Suspension  (Read 1777 times)
Offline Walkers Wagen
  • Dragon Green 8v 2.0 GTI
Suspension
« on: 09 March 2006, 13:50 »
Can you help!!!!
I want to lower my MK3 golf gti, I know the way is coilovers but thats £Â£Ã‚£Ã‚£Ã‚£Ã‚£'s
I'm aiming to make the wheel arch meet the top of the wheel's, I think the front needs to be more than the back. but not going under the arch.
I was thinking eibach springs which I think lowers it 35mm on existing shocks but is that lower enough? I have 17" alloy's and 45 profile tyres.
I don't know what to go to 35mm, 40mm..........
does any one have any pics of the similar setup?
if I were to go for coilovers excluding Koni's what would be a good choice? FK's?????
Offline Dom Mk3
  • Insert wit here
Re: Suspension
« Reply #1 on: 09 March 2006, 14:02 »
I lowered my driver 60mm and the tyres were sitting nicely in the arches.
If you can, always replace the shocks with uprated shorter ones... coilovers aren't too expensive either, found some on venom for around £300 inc. vat
Offline golfpro
  • If in doubt, pay someone else to do it!
Re: Suspension
« Reply #2 on: 09 March 2006, 14:34 »
mine is lowered 40 mil on 17s with 40 profile tyres and ends up lookin good. arches follow the shape of the wheel perfectly in my opinion front and back. also have verry little rubbing, only happens when iv got 3 fatties in the back  :tongue:and thats not often! :laugh:
thats the best mk3 ive seen..ever! its just clean and subtle.. :cool:
Re: Suspension
« Reply #3 on: 10 March 2006, 08:48 »
golfpro do you have any larger pictures just like the one you use for your logo but bigger?
cheers
Offline golfpro
Re: Suspension
« Reply #4 on: 10 March 2006, 09:52 »
that ones fairly similar  :wink:
that shows it fairly well too
Re: Suspension
« Reply #5 on: 10 March 2006, 11:37 »
thanks mate...   what setup did you use? did you just change the springs? and what make were they?
Offline golfpro
Re: Suspension
« Reply #6 on: 10 March 2006, 16:39 »
cant remember what set up it was, but its shocks and springs. would never just get springs done, the shocks will only nackar out quicker and then youl need to uprate them so may aswell get them as a kit while its cheaper. would be worth a look at wherever dom saw that set of coilovers for 300 quid though. could be a good way to go
